Old 3/2/11, 4:02 PM
John Gromkoski's Avatar
John Gromkoski John Gromkoski is offline
Default Rust on metal chimney
I have seen this several times and am wondering what the exact cause of the rust on the metal chimney. Is it rust due to exposure to outdoor moisture - over time, or is it condensation caused corrosion? Or is there some other issue? How would you report this? Thanks.
774 Manor Road
Staten Island, NY 10314
718-514-3393
Need a home inspection in Washington? Check out InterNACHI's listing of Washington certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/2/11, 6:39 PM
Charley L. Bottger's Avatar
Default Re: Rust on metal chimney
John I get a little yancy when I see rust on the exterior of the double wall pipe which can be to any number of reasons. An old trick I use to determine if the rust is caused as a result of the inner lining being deteriorated which is my main concern. I just fire off the appliance and let if run for a while and if the duct located at the rusted spot burns my hand to where I can not hold on to it tells me the inner lining is gone its just a judgment call as its not visible. That is why the MFG of double wall pipe stamps the pipe 1 inch clearance to combustibles. Its strictly a safeguard for when the pipe starts to age.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 3/3/11, 10:23 AM
How would you report it, assuming I did not perform the test you described?
774 Manor Road
718-514-3393
Old 3/3/11, 11:10 AM
Joe Funderburk, CMI's Avatar
"The metal flue is badly corroded and should be replaced before it fully deteriorates."
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 3/3/11, 12:54 PM
Thanks. Sometimes the answers are simple and right there. I just like to understand the reason for it, other than the obvious moisture and age, if there is one.
774 Manor Road
718-514-3393
Old 3/3/11, 7:53 PM
I don't fool around with CO pipe someone will go to sleep and not wake up.
If it's bad or even looks bad call for replacement better to error on the side of caution. I use the word (appears) a lot in my reports
NACHI Member
State License # 130
Old 3/3/11, 8:00 PM
Charlie, that's usually the right way to approach such things.
As a side note, I also use the word appear(ed) a lot in my reports. I write my reports in the past tense because the reader will be reading it at a later time, and also because things that were defective may get corrected after my inspection. For instance, "appeared" instead of "appears", "was" instead of "is". I know there was some discussion about this method of report writing somewhere on this board in the past.
774 Manor Road
718-514-3393
Old 3/4/11, 12:38 PM
Jeffrey R. Pope's Avatar
Good info Charley. Thanks.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
What's Inside A Chimney mcyr Inspecting HVAC Systems 14 9/17/08 6:11 PM
Difficult Chimneys thance Inspecting HVAC Systems 2 1/29/08 8:16 PM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 8:10 AM
metal chimney clearance from trees jweinberg Exterior Inspections 5 11/3/06 11:40 PM
metal chimney height jclark1 Exterior Inspections 7 7/6/06 5:37 PM
