What would cause the Rust/moisture at the burner ports.
The unit is a Armstrong manufactured in 2001. It appeared to be venting properly and the A coil is below the burners. Thanks |
Bump
IMHO,
Looks like some condensation. I would comment about it, and recommend like all gas fired appliances, it should be inspected and service regularly by a professional. tom |
Paul Tos is a non-member guest and is in no way affiliated with InterNACHI or its members.
Would write it up as previous poster stated.
For reference: Possible cause for this would be a switch over from a gravity type exhaust system (less then 70% efficient usually a 5 in pipe) being converted to an induced motor exhaust (80% efficient usually a 4 in pipe), and then venting through a standard brick chimney (inside or exterior - condition from picture makes me believe an exterior in this case) w/o installing required flue liner. Believe what happens, is that in the gravity type exhaust, standard chimney is allowed to heat properly, as the air is heated, it rises. Thru the new 80% induced motor exhaust, the heated air never propertly warms the chimney due to inducement, thus causing excessive condensation. |
Incomplete combustion
http://www.nationalfurnace.com/advice.htm Reccomend CO detector be installed in every house with fuel appliances and or fireplaces. Last edited by bkelly2; 2/23/07 at 8:45 PM.. |
A good pdf 1.+ mb file which hits on combusiton air venting sizing and theory
http://www.duravent.com/tech.htm#tech then click on sizing handbook picture 2/3 down on page right side to download |
Low heat exchanger temp from a/c, condensing ambient air moisture.
Joe Kormos A-1st Look Home Inspectors Inc. 630-201-0933 Your 1st Choice in Property Inspection Professionals www.a-1stlookhomeinspectors.com www.a-1stlook.com Let us look before you buy...for peace of mind “Thinking is the hardest work there is, that’s why so few engage in it. ” Henry Ford |
| Looking for info to buy new oil burner | Bill Shaw | Inspecting HVAC Systems | 3 | 11/13/07 1:51 PM |
| Outside wood burner furnace | abishop | Inspecting HVAC Systems | 7 | 8/30/07 11:31 PM |
| Wood Burner and Gas Furnace No No's | bmargiotti | Inspecting HVAC Systems | 2 | 4/24/07 8:43 AM |
| Secondary condensate ports | bking | Inspecting HVAC Systems | 16 | 9/14/06 6:29 PM |
