Old 9/18/10, 5:22 PM
Christopher Currins's Avatar
Default Rust at suction line
Would rust on suction line and green stains warrant further evaluation at this 6 yr. old unit located at 2nd floor closet?
Or would foam sleeve replacement be enough?
rust-suction-line-hpim7537.jpg   rust-suction-line-hpim7538.jpg   rust-suction-line-hpim7539.jpg
Christopher Currins
Certified, Licensed
Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/18/10, 8:23 PM
James E. Braun, CMI's Avatar
Default Re: Rust at suction line
The staining of the filter is worth mentioning.
Old 9/18/10, 8:25 PM
Next time if it has insulation in the blower cabinet, you ought to take a moisture reading. Nasty crap can grow on the insulation if damp enough.
Old 9/18/10, 9:44 PM
Brian E. Kelly's Avatar
Not sure Chris, could go either way for me..
I now put in the summary of all my reports to have the client review all HVAC Service records, and if the records are either unavailable or over a year old I recommend a service anyway....
Old 9/18/10, 9:51 PM
Joe Funderburk, CMI's Avatar
I don't see any "rust". I see a need for full insulation on the refrigerant line at the cabinet. The condensate drain also needs a clean-out. I ususally insert the photo below in my reports to show them what it ought to look like.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 9/19/10, 10:40 AM
Jeffrey R. Pope's Avatar
No.
I don't see the "rust," but for the problem you've described and photographed, this is the solution.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/19/10, 10:48 AM
cjustason's Avatar
cjustason cjustason is offline
Insulate the line once it's dried , and the green stain is oxidation from the copper. Copper does not rust. Both issues will "go away" once the line is insulated properly.
Old 9/19/10, 2:48 PM
Thanks for the replies. Rust was a bad choice of words I used as a "slang" to describe the corrosion (green rust) in the post, well aware copper doesn't rust.
I felt like Brian it could go either way. The house has been empty for at least 6 months and first time buyers.
An observation from a well respected "ghost" member is the air leakage at the filter door sucks the condensation onto the filter (green stain).
With that being said also addresses that continual moisture may have grown non-visible mold that could have contaminated the ducts and IAQ.
Christopher Currins
Certified, Licensed
Old 9/19/10, 5:43 PM
I hope you don't really believe that. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 9/21/10, 11:20 PM
Gary Reecher Gary Reecher is offline
Send a message via Yahoo to Gary Reecher
Please Note: Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
As stated drain needs clean out also a tee stand pipe.
Inuslation on suction line bhoagland Inspecting HVAC Systems 16 12/7/09 5:20 PM
Excessive Rust on gas line bhartley Plumbing Inspections 3 10/3/09 5:11 PM
Sweating Suction Line mbirenbaum Inspecting HVAC Systems 2 9/1/08 10:20 PM
