Old 12/22/11, 5:16 PM
Default Safety: what dangers do inspectors face inspecting oil-fired combustion appliances?
I never see them in Colorado, so I'm not very familiar with them. With gas-fired combustion appliances, there's the risk of explosion and fire from pre-ignition. What are the danger associated with oil-fired appliances like furnaces, boilers, and water heaters? Do they make oil-fired water heaters?
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Need a home inspection in West Virginia? Check out InterNACHI's listing of West Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/22/11, 7:57 PM
Greg Keene, CPI's Avatar
Greg Keene, CPI Greg Keene, CPI is offline
Default Re: Safety: what dangers do inspectors face inspecting oil-fired combustion appliance
Excellent questions Kenton - I have to inspect my first one in the AM here in CO. Not sure what to look for other than have it insepcted by a qualified HVAC tech. Any help guys?
Greg Keene
Clear Choice Home Inspections
Evergreen, CO
303-674-3234
greg@clearchoice-hi.com
Old 12/22/11, 8:22 PM
An HI An HI is offline
Please Note: An HI is a non-member guest and is in no way affiliated with InterNACHI or its members.
There's a bit of info here that will get you started:
http://oee.nrcan.gc.ca/equipment/heating/13082
http://www.granbyindustries.com/en/p.../3/paradigm/94
Carson and Dunlop's report appendix has a bit on oil-fired heating equipment.
And, yes, there are oil-fired hot water heaters.
Old 12/22/11, 8:55 PM
Wayne B. Wilson's Avatar
Kenton
Less danger the gas fired IMO
Problems Oil leaks
Things not to do
do not reset more the twice if flame is not present
Check for excessive soot. Keep in mind it will not be clean as a gas fired unit
Check flame
Check flue pipe
check limits / fan control
Check damper
Look for condensation if it is a high efficiency type going into old brick chimney
And one word do not stick your tongue on the electrodes lol
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 12/22/11, 8:56 PM
I didn't even know anyone could buy heating oil here, Greg.
(303) 717-8940
Old 12/22/11, 8:58 PM
Originally Posted by wwilson3 View Post
Kenton
Problems Oil leaks
Things not to do
Check flame
Check flue pipe
Check damper
Wayne, what do you mean by "reset" and what is the danger if you do?
(303) 717-8940
Old 12/22/11, 9:22 PM
Kenton if you reset ( furnace didn't fire) It pumps oil into the chamber . two many times floods the fire box and you will have a uncontrollable fire.
Wayne Wilson
865-256-1490
Old 12/22/11, 9:28 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
For fear of being shot down by the three stooges. The red button is a reset and should never be pressed more than twice. You will not need to touch this button in your inspection. You should also not view the flame unless you know what to look for.
Inspection of an oil-fired system is not anything like natural gas.
The lines are also different colors and must be installed according to proper guidelines. The guidelines are the CSA B 149-09
I would recommend you find the equivalent in USA.
THE RIGHT TRAK
CIAQP, IAC2
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 12/22/11, 10:18 PM
Charley L. Bottger's Avatar
Just a different name for diesel different grades
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 12/22/11, 10:54 PM
Kenton - I was surprised too - but Wayne called me and gave me some hints on what to look for - will try my best and will let you know how it went. I HATE first time stuff.
Greg Keene
Evergreen, CO
303-674-3234
Old 12/23/11, 3:03 AM
Kathleen Luuk's Avatar
Kathleen Luuk Kathleen Luuk is offline
Trying to remember my CD course material, one thing I do remember is the reset button info that others have already informed you of. I will drag out the binder tomorrow at some point and see what, if anything I can add for you Kenton.
when you have eliminated the impossible, whatever remains, however improbable, must be the truth.
Sir Arthur Conan Doyle.
If you have ten thousand regulations you destroy all respect for the law.
Winston Churchill
Old 12/23/11, 4:24 AM
KEVIN WOOD's Avatar
I have taken
Practical Guide to Safe Oil
Installation Codes for Furnaces and Boilers
Installation of Oil Burning Equipment
B149 Codes update
Safe Inspection of Oil tanks
Installed Oil tanks and furnaces
Monitors and wood stoves
Wett site basic
Natural Gas and Propane Installation code
Carson Dunlop heating one and two (Teacher)
HRAI Installation and designer
Advanced HVAC
And countless CE hours on HVAC
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 12/23/11, 4:59 AM
FINICKY F'D UP BOARD HERE!
By clicking on "go advanced", just lost a post that took me 15 minutes on a long list of "things to check"
POS!!!
Old 12/23/11, 9:11 AM
Originally Posted by kwood View Post
I have taken
B149 Codes update
Wett site basic
Advanced HVAC
Hi Kevin I worked on Boilers, forced air furnaces, Licensed Oil burner Mechanic Unlimited BTU in Ontario for 23 years Certified underground storage. 15 years
Plus i have stayed in a Holiday Inn lolol
Wayne Wilson
865-256-1490
Old 12/23/11, 9:48 AM
David A. Andersen's Avatar
DANGER: Don't listen to Linus and pee on the transformer ignition to test it (10,000 volts)!
There are about 46 parts in an oil burner gun, any one could cause failure.
The motor should run quietly and smoothly.
The squirrel cage blower assembly should not be rotted out. Must be cleaned periodically.
The oil pump should not leak.
Pop the transformer and examine the electrodes for arcing.
The nozzle should be clean and not drip oil. The nozzle should be changed yearly and must be the appropriate size. It must be the proper orifice size, spray angle and could be hollow or solid clone design.
The igniter probes discharge against the nozzle and must be properly adjusted (special tools required). The electrode gap should be no more than 1/8 of an inch apart and no more than one half of an inch above and forward of the nozzle. Porcelain insulators must be kept clean or they will short out. The spark should jump across at least a 1 inch gap with the blower turned off. Adjustment per equipment manufacturer.
The throat of the gun should be intact (not burned out). There should be no discoloration or build up.
The nozzle of the gun should not extend past the refractory insulation inside the furnace.
The cadmium cell above the burner must be clean and able to see the fire adequately.
The tank filter should be changed yearly.
Barometric damper operation should be free moving.
Check for delayed ignition at start up. Should fire right off and not pop or blowback during ignition.
Pulsation noted during operation is caused by positive pressure in the combustion chamber indicating there's not enough draft.
The draft should be .02 inches of water gate.
Positive pressure may be caused by having the air shutter open too much, the chimney is too small or partially blocked or not high enough.
If anyone made any changes to where the tank is located, the type of pump may not be compatible if it is a single stage operating in vacuums at or above 15 inches of mercury. This causes the oil to foam before it reaches the nozzle to be atomized.
A faulty nozzle has an irregular flame pattern. The flame tips should be sharp (but not excessively).
If you see oil on the floor of the furnace room it is a serious condition. An air leak in the oil suction line causes the nozzle to drip. It can be from loose connections or fittings or from a bad pump seal.
Unusual sounds during operation indicate worn and broken parts which should be immediately replaced as failure may cause a significant breakdown which could be avoided.
Noises come from loose fans, loose shutter, worn pumps, dirty strainer, air in the oil, motor coupling is worn, motor and pump are not properly aligned, relay contacts not seating, restricted oil lines,
Any indoor tank should be at least 7 feet away from the furnace.
The oil storage tank should be tilted away from the outlet pipe to collect moisture and crap.
Any black soot observed in the furnace room is an indication of blowback and improper ignition current or in the past.
I taught air conditioning installation to the oil burner technicians at the American Fuel Institute. This is what they taught me!
BPI# 5015804
Vacation Resort Inspectors in Coeur d’Alene, ID 83815 rspriggs Ancillary Inspection Services & Additional Topics 0 1/9/09 3:40 AM
Property Management Inspectors in Coeur d’Alene, ID 83815 rspriggs Ancillary Inspection Services & Additional Topics 0 1/9/09 3:21 AM
BC is acting on the new bill jkoong Canadian Inspectors 21 2/19/08 7:38 AM
Another reason to recommend CO testers rnewman1 Interior Inspections 2 10/12/06 7:47 AM
