Old 4/17/13, 4:59 PM
James L. Campbell James L. Campbell is offline
Default Scorch marks
I have seen several heat pumps lately with scorch marks around the suction line where it enters the air handler. In one case the grommet was burned as well. What causes these scorch marks?
In all cases I have recommended an HVAC specialist.
Jim Campbell
Orion Home Inspection
Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/17/13, 5:33 PM
InterNACHI Applicant
Default Re: Scorch marks
Bad torchwork by the installer when brazing the refrigerant lines
Chuck Evans (TREC #7657)
Houston, TX
Old 4/17/13, 6:02 PM
Charley L. Bottger's Avatar
Jim Campbell
You should asked your question before you send your report you are providing a good laugh for some HVAC tech as was stated some guy with a torch that would have been better off if he had stayed home that day
http://www.oklahomathermalinfraredimaging.com/
http://www.freedomexpressinspections.com/
Master HVAC Mechanic Retired
Level III Thermographer # 8486 Infraspection Institute
CMI Certified Master Inspector
Residential/Commercial Inspections
Moisture Intrusion Expert Witness
580-268-3340
Old 4/17/13, 6:19 PM
Thanks guys. Had another one today, so I'll save the embarrassment this time.
Jim
Does this look like Scorch marks? lking Electrical Inspections 3 4/5/13 7:40 AM
This Friday marks the 11th anniversary of the U.S. keeping POWs in perma-captivity. gromicko Miscellaneous Discussion for Inspectors 105 1/17/13 7:01 PM
Outlet with burn marks pnarron Electrical Inspections 5 3/21/10 9:18 AM
Misuse of Title rwand1 Canadian Inspectors 40 10/15/06 8:29 AM
Scorch Marks on Tankless Water Heater jnicholson Inspecting HVAC Systems 8 9/6/06 7:28 AM
