Old 5/10/13, 12:56 AM
mkrueger mkrueger is offline
Default Screw in the cooper pipe of the boiler???
Is it possible a Plumber/HVAC tech put a hole in the copper pipe of the boiler system and then used the screw to plug the hole?
If so what would they be checking?
I don't feel comfortable with holes in the plumbing...
Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/10/13, 2:24 AM
Roy D. Cooke, Sr's Avatar
Default Re: Screw in the cooper pipe of the boiler???
Not the way I would do it I expect this was to let the air out .
Old 5/10/13, 8:00 AM
Charley L. Bottger's Avatar
Suspect Roy is correct about the air bleed if so its improper. Recommend a standard air bleed be installed
http://www.oklahomathermalinfraredimaging.com/
http://www.freedomexpressinspections.com/
Master HVAC Mechanic Retired
Level III Thermographer # 8486 Infraspection Institute
CMI Certified Master Inspector
Residential/Commercial Inspections
Moisture Intrusion Expert Witness
580-268-3340
Old 5/10/13, 8:50 AM
Wayne B. Wilson's Avatar
I would say a do it your self bleed, repair needed shouldn't be a big deal to fix , did you see any other bleeders? i wondering why one there. perhaps they were going to install a gauge and forgot
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
https://www.myhomeinspection.net/
Old 5/10/13, 11:10 AM
Scott May, CMI's Avatar
Scott May, CMI Scott May, CMI is offline
Send a message via Skype™ to smay
could be an attempted fix by the homeowner. I can't see any plumber doing this ..but could depend on how many pops he had that day!
Try not to become a man of success but rather to become a man of value!
Any information posted by me on this site should be considered as a personal opinion, belief or assumption and cannot be attributable by way of association to any other company, person or agency.
http://eyespy-homeinspections.ca
email: [email protected]
Serving: Acton, Burlington, Brampton, Cambridge, Durham, Erin, Guelph, Georgetown, Hamilton, Kitchener, Mississauga, Oakville, Waterloo
Old 5/10/13, 11:20 AM
Wayne, I did see one auto air vent but it was all corroded.
Thank you all for your help.
I don't see a lot of boilers. Most home in my area have gas hi eff. forced air.
Old 5/10/13, 4:43 PM
Mike probably wasn't working if it was corroded
Wayne Wilson
865-256-1490
Do you put polybutylene in the Summary? jfunderburk Plumbing Inspections 42 11/3/13 6:47 PM
Pellet stove help chellickson General Inspection Discussion 23 8/19/10 1:23 AM
vent pipe in return dlee2 Inspecting HVAC Systems 2 2/18/10 12:51 PM
Is this allowed? belliott Plumbing Inspections 4 7/15/09 6:40 PM
Identify ABS defective pipe mcyr Plumbing Inspections 6 1/29/09 6:39 PM
