Old 8/21/11, 11:19 PM
Ralph Hickox Ralph Hickox is offline
Please Note: Ralph Hickox is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default secondary drain on a vertical unit
an inspector gave me a hit on not installing a secondary drain on a vertical hvac unit. I used a condensate pump with the primary draining into it and the float on the pump wired to shut unit down. Honestly i have never seen a secondary piped up on vertical unit. On a horizonal unit i know you have to have the primary ran out and the emergency pan either run out or a float switch wired in. Just never seen it on vertical...is that national code or is that a local code he is enforcing?
Need a home inspection in Nevada? Check out InterNACHI's listing of Nevada certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/22/11, 12:20 PM
Charley L. Bottger's Avatar
Default Re: secondary drain on a vertical unit
What kind of a inspector are we talking about Home inspectors do not inspect for code and have no means or authority to enforce anything are you referring to the AHJ (Authority having jurisdiction)
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 8/23/11, 9:07 AM
Robert J. OConnor's Avatar
What would happen if the drain line from the equipment to the condensate pump gets clogged?
If your above finished space or in a finished basement you should have a pan below the equipment with a secondary drain or float switch, or you can install a separate secondary drain line from the equipment condensate tray to a visible location. Model codes like the IRC have another option for installing a water detection device to shut down the equipment if the condensate rises above the primary, but before the level reaches the top of the equipment condensate tray ... but I haven't seen that yet. See IRC M1411.3.1 for the model code provisions.
Your local code mileage may vary, but it's sounds like an issue from a home inspectors point of view.
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
Condensate Drainage jevans Inspecting HVAC Systems 28 11/27/10 2:55 PM
No secondary (pan) drain in Attic Okay per builder mgault Inspecting HVAC Systems 14 1/30/09 8:38 AM
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
