From an inspection on Saturday. Tempstar model NUKK075DG05
Unit had been installed as propan in 1991 and converted to natural gas in 1992. The third pic says a secondary heat exchanger was installed in 2003. 1. Do any of the HVAC guys here know if this unit came with a secondary heat exchanger originally? (it is apparently a 90+ furnace from my research) 2. The unit is rated 75K BTU L.P. and only 60K BTU for the alternate fuel which I assume is Natural gas. Is that correct? (Most of the converted units I have seen don't have this much difference between the two possible fuel sources and when I converted my own boiler I was suppied with a new rating decal for the new fuel source. N.G/L.P. Thanks in advance for any enlightening comments. ![]() ![]()
All plus 90 furnaces have a secondary heat exchanger. That's where the extra efficiency comes from.
On some further thought I was also wondering if the 60K input BTU was an alternate setting for the burner. let's see what some of the HVAC guys have to say. |
Keep in mind, that anyone can write "Secondary heat exchanger installed in 2003".
Do not write down that the H/E was replaced 4 years ago. You have no clear evidence. Simply write down what you see written on the casing and recommend further evaluation when the unit is serviced. I always recommend service and cleaning upon moving into the home and annually thereafter. |
I always reccommend annual service of the equipment. |
| Inspection of HVAC by an area inspector. | dmcauley | Inspecting HVAC Systems | 13 | 3/21/07 11:03 AM |
| Condemned Furnaces Spark Safety Issues | Gary Reecher | Inspecting HVAC Systems | 7 | 3/8/07 8:17 PM |
| Radiant Heat Transfer | rmyers1 | Structural Inspections | 0 | 5/31/06 11:21 PM |
| Cracked Heat Exchanger | jallingham | Inspecting HVAC Systems | 26 | 5/11/06 10:12 PM |
