Old 7/15/08, 7:09 PM
dbucknavich dbucknavich is offline
Please Note: dbucknavich is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default shared condensate drainage
Hey there, I saw a house today which had both primary drain lines tee'd together. (pic attached)
a part of IMC 307.2.2 says "where the drian pipes from more than one unit are manifolded together for condensate drainage, the pipe or tubing shall be sized in accordance with an approved method."
Does anyone have access or knowledge concerning these sizes and method?
Thanks
Old 7/15/08, 9:37 PM
Charley L. Bottger's Avatar
Default Re: shared condensate drainage
Thanks
You are not being very clear here I am assuming you are talking about two separate units and connecting two primary drains together if that is the case I personally would not have a problem with the size of the drain line unless perhaps the tonnage was 4 or 5 ton with lots of coil surface smaller tonnage system will not make that much water that one 3/4 inch line could handle it. I would think in AZ with no humidity there would be no problems. Don't recall what the IRC states never had an occasion to connect two system together usually both coils are too far apart for this to be a concern.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
1 condensate line...... Scott Schultz Inspecting HVAC Systems 2 11/4/07 6:18 AM
Condensate piping dmacy Inspecting HVAC Systems 15 3/13/07 12:17 AM
gutter downspout to basement drainage system David Paterson Exterior Inspections 2 12/18/06 6:27 PM
TPRV line and condensate line marriage ccarrington Plumbing Inspections 3 4/29/06 7:59 AM
