lvass is a non-member guest and is in no way affiliated with InterNACHI or its members.
I did an inspection today and found that the new hot water heater and new furnace are sharing a vent pipe. Both are gas and the everything is new. Does anyone see any serious issues with the venting? Thanks
| Need a home inspection in Oklahoma? Check out InterNACHI's listing of Oklahoma certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
No..
No, but where is the cold water shutoff.?
Is that a return in front of a furnace?
So you guys don't see a problem with an electrical outlet on the floor near the water heater?
Up in here in Ontario you can no longer do it. Have to be separate. Gerry Pallotta Alota Home Inspection Services www.alotahomeinspect.ca Greater Toronto Area Home Inspector Mississauga Home Inspector |
Ha Ha they are both bad. I think someone is testing us. |
Especially when that TPR blows. lol
Oh My!
Hope that is the bottom floor,and with no GFCI they better wear rubber boots. |
Thanks guys. Here are a few more. How in the hell do I write this one up?
Shut off needs a wrench...... Drain pan needs a drain pipe.........
Thermostat wire........ Who knows but low voltage and could be a few things...... I would ignore all, but the drain pan is interesting. Was this on the second floor? |
No, this house is only a single story.
Maybe they put the drain pan there rather than move the shock box near the furnace.
If this is in the basement it is unusual to find a drain pan unless flooding will cause damage near by. Always used to protect something ,so you need to figure if it should be piped to a nearby floor drain. |
All this equipment is in the living space of the house. I believe it need needs to be plugged or vented to the outside some how. If this room floods, it floods into the bathrooms and hallway until it over spills into the intake.
You are correct.
Thank You Bob and everyone for your help. 5am comes early.
| Pellet stove help | chellickson | General Inspection Discussion | 23 | 8/19/10 1:23 AM |
| Air admittance valves everywhere | apfaff | Plumbing Inspections | 13 | 4/16/07 9:17 AM |
| Furnace and Water Heater Sharing Vent | ehyde | Inspecting HVAC Systems | 2 | 4/11/07 5:07 AM |
| Gas and oil hot water tank and Boiler Share Vents | hvanderbeek | Miscellaneous Discussion for Inspectors | 8 | 1/25/07 5:22 PM |
