lagudo is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hi Guys,
I have a question on the cycling of my NG furnace. When called upon for heat it fires up but only stays on for 3 to4 Minutes then shuts off and stays off for about 5 to 7 minutes. It's not even close to reaching the temp. that has been called for. Needless to say, this never brings the temp. high enough to make a difference. I thought that maybe it's a faulty thermostat but I have never had any problem with cooling and short cycling. I have called to get my unit serviced but I am looking for information I why is this so and what component could be causing this problem. Thanks in advance. |
Louis,
In addtion to what Charley said, tell us more and post a picture of the unit with the service doors off. There are some very qualified people here willing to help another HI. |
Is the Filter dirty ......... Cookie
If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
Is this a high eff. or mid eff. furnace?
Have the homeowners closed the supply ducting down or closed off a number of floor vents? |
Furnace short cycling.
No heat to home. Possible hi temp/fan limit switch problem. Recommend further evaluation by a qualified service technician. a wise man once told me, "life is short, so learn from your mistakes, but more importantly learn from others mistakes as well because you don't have time to make them all yourself" Regards, Mark |
Jeff Campbell Campbell Property Inspections http://www.maineshomeinspector.com Pittston, Maine NACHI04013010 |
Mark I would leave out the third line.
...or the heat anticipator in the thermostat.
twasion is a non-member guest and is in no way affiliated with InterNACHI or its members.
Circulation pump may be inop.
| Short Cycling | twheeler | Inspecting HVAC Systems | 21 | 11/21/10 4:12 AM |
| Furnace Problem Comments Welcome | rfrost | Inspecting HVAC Systems | 24 | 10/21/07 7:26 PM |
| Sweating decision:Settle for lower SEER to use existing furnace? | Fel Randolph | Inspecting HVAC Systems | 2 | 6/6/07 3:56 PM |
| Condemned Furnaces Spark Safety Issues | Gary Reecher | Inspecting HVAC Systems | 7 | 3/8/07 9:17 PM |
| My furnace short cycling | mtimpani | Inspecting HVAC Systems | 10 | 1/16/07 1:07 PM |
