Alejandro Garcia is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hi all I am new to this web site just have a few questions about my furnace.
I have a gas furnace, it has a honeywell t8602d thermostat I notice that recently my furnace is cycling more than usual about 3 times within 10 minutes, I replaced the air filter and open all the bents, cleaned the flame sensor but still doing the same. I am thinking I might be the thermostat settings. Does anyone know what these numbers do ? are they for the heat anticipator settings? thanks ![]() ![]() ![]()
| Need a home inspection in Colorado? Check out InterNACHI's listing of Colorado certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Eventually you will freeze your a s s off and come to your senses, then you'll call an HVAC contractor to fix your short cycling problem.
BPI Certified Professional Building Analyst BPI Certified Envelope Professional Infraspection Institute Certified Level II Thermographer # 8510 www.dapkusinspections.com www.chicagoinfraredthermalimaging.com www.mychicagohomeinspector.com www.commercialbuildinginspectionchicago.com Professional Infrared Network Chicago Energy Audit Aerial Infrared Inspection Certified Infrared Thermal Imaging |
install manual has the codes & wiring diagrams
http://customer.honeywell.com/techli...0s/69-1510.pdf problems continue contact qualified hvac specialist ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
| Short Cycling | twheeler | Inspecting HVAC Systems | 21 | 11/21/10 3:12 AM |
| Short Sales: A Fraying Lifeline for Homeowners | jburkeson1 | Miscellaneous Discussion for Inspectors | 4 | 10/6/09 3:52 PM |
| Short cycling of furnace | lagudo | Inspecting HVAC Systems | 12 | 10/17/07 8:47 PM |
| My furnace short cycling | mtimpani | Inspecting HVAC Systems | 10 | 1/16/07 12:07 PM |
