Old 8/2/07, 1:48 AM
Charley L. Bottger's Avatar
Default What should this tell you
When I first started the A/C unit there was no water on the floor in front of the A-coil. What is the obvious with out the water present.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 8/2/07, 8:10 AM
Bruce M. Graham, III's Avatar
Bruce M. Graham, III Bruce M. Graham, III is offline
Default Re: What should this tell you
rusted out drain pan, what is the top tubing going into the coil box,
looks like poly going to copper?
Bungalows to Mansions
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 8/2/07, 9:07 AM
You are right the pan was rusted out the poly tube is the discharge line from the sump pump installed in the plenum the black cord is the electrical supply for the pump. Guess they thought it would be cheaper to install a pump than replace the coil and pan. Another reason for Home Inspections.
NACHI Member
State License # 130
