Is there a problem and if so how should I write it.
Gary Porter GLP's Home and Mold Inspections 321-239-0621 Certified Commercial Mold Inspector Serving Orlando, Kissimmee, Winter Park, Winter Springs, Oviedo, Titusville, Celebration, Harmony, Avalon, Windermere, Deltona, Debary, Sanford Orange County, Seminole County, Volusia County, Osceola County www.homeandmoldinspections.com |
Roy Cooke sr |
Service furnace prior to closing of title.
bkelly1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Excessive rusting at the heat chambers, recommend service / repair of unit prior to closing of property.
Thorough diagnosis and repair by a qualified licensed HVAC contractor prior to close of escrow. or,
Replace the piece of ****!. |
EXCESSIVE RUST ON OR AROUND BURNER
The inspector visually observed that heavy rust particles exists and cover the burners, and the area under the burners. Normally this is a sign of additional damage by rusting around or inside the draft diverter. However, other problems may exist. (i.e. Excessively rusted heat exchangers will deposit considerable rust atop and around burners of the heater). The presence of excessive rust particles may cause interference with the flame resulting in further problems. This defect/safety concern could be a simple fix or a costly repair or replacement of the heating system. The proper evaluation would require invasive evaluation vs. our visually observed evaluation. The inspector strongly recommends that a Heating Contractor be contacted for assistance and further evaluation/advice prior to close or escrow. www.buildingcenter.org Quickly determine the date of manufacture, age or production of most HVAC and Water Heating equipment |
I would also recommend not using the heat mode due to a possible crack in the heat exchanger until proper repairs, technical evaluation or replacement is completed.
I have seen alot worse that were not leaking co, and were not cracked. I also try not to write paragraphs for explanations, b/c people do not read them.. But that is just me.
| AHJ's opinion differs from code...how would you write it up? | jhugenroth | Plumbing Inspections | 9 | 8/31/09 8:04 PM |
| How would you write This | gporter | General Inspection Discussion | 12 | 9/24/07 2:38 PM |
| Tidbits from the ASHI Message Board | jbushart | Miscellaneous Discussion for Inspectors | 126 | 4/27/07 11:05 AM |
| Write It up or not? | thejnicki | Electrical Inspections | 5 | 8/7/06 3:49 PM |
| How should I write this | gporter | Exterior Inspections | 11 | 4/15/06 9:39 PM |
