Old 3/31/09, 7:27 PM
mnicholet's Avatar
mnicholet mnicholet is offline
Please Note: mnicholet is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Single wall vent connector
Please remind me about Vent connector(s) rule of thumb. These pictures are a single wall non B-type for natural gas hot water tank and mid efficiency furnace manifold into a L vent metal chimney flue. Combustible clearances appeared to be about 6 inches. Is it OK to use this single wall vent connector, should it not be a B vent consistently?
Furthermore, I believe this is mid efficiency furnace was manufactured in 1992, can anyone please confirm?
Carrier
model# 395CAV042075
serial# 4192A21025
Much appreciated!
ID:	27768   single-wall-vent-connector-dsc08166-medium-.jpg.JPG
ID:	27769   single-wall-vent-connector-dsc08167-medium-.jpg.JPG
ID:	27770   single-wall-vent-connector-dsc08168-medium-.jpg.JPG
Find an InterNACHI certified Vermont Home Inspector (and anywhere else in North America)
Old 3/31/09, 7:31 PM
Default Re: Single wall vent connector
Single wall is typically used from the furnace to the chimney pipe (B-vent) which is used up through the home and out. Single wall clearance is 6" to combustibles.
Larry Kage, CMI
231 929 3525
Old 3/31/09, 9:02 PM
Mark,
Looks to me like picture #4 shows singlewall elbow into B'vent is closer than 6" to wood...?
I'd also recommend sealing previous screw holes and joints. Minimal concern probably, but technically accurate to call.
Is that R/A grill installed on ductwork, plenums, etc....?
Old 3/31/09, 9:26 PM
mnicholet's Avatar
Originally Posted by gveal View Post
Mark,
Greg, your right it is a little less than 6". That grille you see is a supply grille on the supply plenum.
Moisture Management mcyr Exterior Inspections 15 9/8/08 12:11 PM
Single wall into B vent question sspradling Inspecting HVAC Systems 1 5/31/07 2:04 PM
Gas and oil hot water tank and Boiler Share Vents hvanderbeek Miscellaneous Discussion for Inspectors 8 1/25/07 5:22 PM
