Old 12/18/06, 12:49 AM
David Nasser's Avatar
David Nasser David Nasser is offline
Default Size of the Airconditioner
How can you tell the size ? and is that
critical to a good inspection.
David
Pyramid Home Inspections
Old 12/18/06, 1:33 AM
David A. Andersen's Avatar
Default Re: Size of the Airconditioner
The model number of the unit and compressor.
It gives you worthless information unless you know what you are doing with it. It has nothing to do with home inspection.
Old 12/18/06, 4:54 AM
David,
I usually list the Unit(s) model #, which indicates the capacity. I don't comment of the sizing for the area served, because that falls outside our perview of H/I. It's good information for the Client.
Old 12/18/06, 7:19 AM
Barry Adair's Avatar
DN,
This depends on the question(s) being asked of you.
The most common around here are "How many tons do I have?", "How old is it?", or "Is this unit efficient?" All are fairly easy to answer but do not tell the story about the installed system.
Not all systems are matched size condensing unit and evaporator coil, but all should be run through a program to calculate the many variables.
Sizing info, http://www.eere.energy.gov/consumer/.../mytopic=12340
Preston Guide
http://www.prestonguide.com/
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 12/18/06, 8:37 AM
ccbrands1 ccbrands1 is offline
Please Note: ccbrands1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
to elaborate, they're is usually a number divisible by 12 in the model number.
24 - 2 ton
30 - 2.5 ton
36 - 3 ton
40 - 3.5 ton
etc, etc.
this # indicates the size ( tonnage ) of the unit, but nothing else.
I always point out the tonnage in my report, but never elaborate on its adequacy in respect to the home...just report on it's performance the day of the inspection.
Old 12/18/06, 11:48 PM
Joe Funderburk, CMI's Avatar
David
My state's SOP requires me to report the BTUs, if available.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 12/19/06, 12:07 AM
JLilly's Avatar
JLilly JLilly is offline
I list model, serial, tons, btus and age as a service to my client. I'm not required to do it.
James R Lilly, CMIA
www.lhiservices.com
jamesrlilly@lhiservices.com
Home and Mold Inspections Radon Testing
Based in Parkersburg, WV
Serving West Virginia and Ohio
Old 12/19/06, 2:31 PM
Robert J. OConnor's Avatar
The model number of the unit and compressor. It gives you worthless information unless you know what you are doing with it. It has nothing to do with home inspection.
I agree there is not much an HI can do with the size of the system/units, but many do like to report that info just for their clients information.
Some use rough area/ton numbers from local HVAC specialists (they vary greatly depending on the region you are in) to see if the system is in the "ball park" ... but never comment on adequacy of the system. There are way to many variables, and even contractors that use area/ton rules of thumb as a guide to check their calcs adjust those numbers for site specific conditions (ceiling heights, windows/glass, exposure, insulation, tight construction, etc).
However on the other side of the coin, if you do report the size and it's not adequate, the client may later ask why you didn't report that (even though thats beyond the scope of a home inspection ... but they don't know that).
If you do include the size of systems in your reports, I recommend you make it clear that it's for the clients information only, and determining the adequacy of the system is beyond your scope.
JMO & 2-nickels ...
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
Old 12/21/06, 12:49 AM
thanks, get well from your cancer...
Old 12/21/06, 11:55 AM
3.2. Exclusions:
I. The inspectors are not required to determine:
D. The size, capacity, BTU, performance, or efficiency of any component or system.
2.5. Cooling
I. The inspector shall inspect:
A. The central cooling equipment using normal operating controls.
II. The inspector is not required to:
A. Determine the uniformity, temperature, flow, balance, distribution, size, capacity, BTU, or supply adequacy of the cooling system.
Size of service?? cbuell Electrical Inspections 4 4/14/07 4:50 PM
AFCO size and age help please bracine Inspecting HVAC Systems 3 2/15/07 12:23 PM
Flue Size when size matters? msylvester Inspecting HVAC Systems 14 1/20/07 11:29 PM
Size of supply line aobrien Inspecting HVAC Systems 7 1/2/07 12:40 PM
Help Determining Reportable Service Size cbarrows Electrical Inspections 8 7/19/06 7:12 PM
