Old 2/19/10, 3:49 PM
David C. Macy's Avatar
David C. Macy David C. Macy is online now
Default In slab ducts
Looks to me that the ducts were half full of water at one time.
Is the cracking of the ducts a concern? It seemed to be at the top portion. Is this from when they break them for the floor registers?
I have some verbiage that states: In slab ducts are subject to, and prone to water intrusion
Need a home inspection in Idaho? Check out InterNACHI's listing of Idaho certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/19/10, 3:52 PM
Michael Larson's Avatar
Default Re: In slab ducts
Are those clay tile David?
I've seen under slab ducts made of of transite(asbestos) and plastic.
Michael Larson
Hudson, WI
[/I]
Old 2/19/10, 3:57 PM
Mike
Yes they are clay.
Old 2/19/10, 4:07 PM
I think your observation about being half full of water at one time is valid.
I also wonder how the tile you can't see looks
Any under slab water will end up is those ducts so site drainage is of paramount importance.
Write it up and disclaim what you can't see.
Michael Larson
Hudson, WI
[/I]
Old 2/21/10, 2:44 AM
Matthew K. Klein's Avatar
Matthew K. Klein Matthew K. Klein is offline
Sub-slab duct systems are nearly always a problem and the only reason I use the word "nearly" is because I am holding out for finding ONE that did not have problems. I don't think I have seen a one that either did not have water in them or have water stains showing that water had been in them. I have seen clay tiles used for these ducts, as in the photo. Even if the contractor wraps them in plastic, as I have seen, they still leak.
Further, leaks in the ducts can be a route for soil gases to enter the home, especially if the duct is a return. If the area has radon problems, such soil gases can be a serious problem. In that case, I am thinking that the only resolution would be to install new duct work.
Now, maybe someone has observed a subslab system that doesn't have problems, and maybe if the home is built high enough above grade, it might not at least have leak problems. But, I see no way to avoid soil gas migration problems, unless the fan is run constantly and the ducts are on the supply side.
Matthew Klein, P.E., M.B.A.
Criterium Engineers
PO Box 181503
Cincinnati, OH 45018-1503
Phone: 513-474-9600
FAX: 888-747-0427
E-mail: Criterium-Cincinnati@fuse.net
Website: www.Criterium-Cincinnati.com
Moisture in slabs mcyr Structural Inspections 7 8/20/07 7:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 10:26 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 7:53 PM
supply in slab or walls? jeubank Plumbing Inspections 1 7/8/06 10:36 AM
