Troy officials reviewing home inspection records
Incorrect wiring of furnance in Pattison Way home led to fatal carbon monoxide poisoning Friday By BOB GARDINIER, Staff writer Click byline for more stories by writer. Last updated: 10:58 a.m., Tuesday, December 12, 2006 TROY -- City officials will open code enforcement records for review this morning on 13-year-old inspections of furnaces installed in homes on Pattison Way. This comes after Friday's discovery that Hoan Son, 61, had died in his bed of carbon monoxide poisoning in his Pattison Way home. His wife, Lan Son, 55, is in very critical condition at Jacobi Medical Center in the Bronx after firefighters found overwhelmingly high concentrations of the odorless gas. An investigation showed the furnace, first inspected by city code enforcement officials when the development was build more than a dozen years ago, was erroneously wired. It was later discovered that similar furnaces in other homes in the development also were wired incorrectly. According to a local furnace expert, the problem with the unit was that safety switch on the direct vent kit was wired incorrectly. The vent consists of an electric fan that expels dangerous combustion gases through to an outside vent. As a result, if the fan unit failed, the safety switch would not shut off the burner, allowing the deadly gas to fill the home. Gerry Pallotta Alota Home Inspection Services www.alotahomeinspect.ca Greater Toronto Area Home Inspector Mississauga Home Inspector |
If someone were inclined to test these devices:
1. Turn on the furnace. 2. Check to see that the vent motor is running. 3. Remove the small rubber tube on the device that attaches to the round diaphragm disc (pressure switch). 4. The furnace should shut down. |
It's way beyond a typical HI inspection to check things like that which caused a problem mentioned in the article. But if you happen to notice something doesn't look right, or perhaps if you have no idea what you are looking at with higher efficiency furnaces and something just rubs you the wrong way, write it up and have an HVAC specialist check it out.
The safety devices and connections on higher efficiency units can be confusing sometimes even for installers (not that I have ever looked at horizontal conversions on higher efficiency furnaces doing some fill in work with a family HVAC company, and had to look at the instructions and scratch my head for a few minuets before the light bulb went on ... I would stick with "visual observations, using normal operating controls and access", and recommend an HI not even touch any of the wiring or safety hoses/connections. JMO and 2-nickels ... Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
| Anybody read this........... | pcloninger | Miscellaneous Discussion for Inspectors | 1 | 9/19/07 6:18 PM |
| THE "GROUNDING "TRUTH- Article To Read | pabernathy | Electrical Inspections | 1 | 1/1/07 1:14 PM |
| My Wife Needs Your Help - Please Read! | hgordon | Miscellaneous Discussion for Inspectors | 1 | 9/25/06 8:43 AM |
