Skip Erwin is a non-member guest and is in no way affiliated with InterNACHI or its members.
I've posted this out here before but no one knew the answer.
Every once in a while I run across a brown stain around a ceiling mounted HVAC register. What can cause this? I'm thinking condensation caused by a closed register, or condensation from a duct loose from the boot in the ceiling. Anyone see this? Thanks in advance. |
It can also be the result of a low setting of the thermostat some folks just naturally like their home colder than the unit has the capability of reaching. I have seen condensate stains like that when the outside ambient is above 100 degrees and the unit just runs non-stop during the afternoon until late evening. Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
I'm with Charley on this one.
I've seen airflow problems causing condensation on the register due either to closed damper, plugged/bullet-proof/stopped up filters, missing duct insulation either on the duct and/or removed/damaged insulation on or around the register boot. Your example shows that most likely the ductwork is located in an Attic space, but I've seen the same conditions on sidewall or floor installations, where the ductwork is located in basement or crawl space areas. |
It is very common here because the A/C is often on when a sliding glass door to the pool area is left open. The metal register sweats and the drywall sponges it up.
Don't interfere with anything in the Constitution. That must be maintained, for it is the only safeguard of our liberties. Abraham Lincoln www.qualityhomeinspectionsfl.com |
Inadequate insulation at the boot.
| How To Stop Your Home Inspection Clients From Suing You! | rray | General Inspection Discussion | 17 | 6/4/08 2:22 PM |
| Room size requirement for HVAC supply | kweiss | Inspecting HVAC Systems | 3 | 6/9/07 6:58 PM |
| Access to Electrical Panel in Ontario by HVAC Contractors | Nalliah Thayabharan | Canadian Inspectors | 10 | 5/21/07 3:01 PM |
| Condemned Furnaces Spark Safety Issues | Gary Reecher | Inspecting HVAC Systems | 7 | 3/8/07 8:17 PM |
