Old 5/15/07, 10:19 PM
Default Steam humidifier?
This said "steam humidifier" on it. Is the box (says "Honeywell") attached to the furnace a mini-boiler with controls just below it? Then there's the box hanging from the ductwork that says "Autoflow" and has a copper line coming into it.
I just took some quick pictures while dropping off a radon monitor so I haven't looked at these things carefully and I'm going back tomorrow. Don't thnk anything that says "Honeywell" is going to be a boiler though. Awful big for a control box, though.
Is anyone familiar with these components?
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 5/16/07, 7:42 PM
David A. Andersen's Avatar
Default Re: Steam humidifier?
You got the steam thing correct.
The Honeywell thing is a zone controller. You will find several t-stats around the house, all for the same unit. They will not run in heat and cool at the same time. Things may not "happen" right away when you turn them on. Looks like you have four zones running.
The metal rod with the weight hanging down is a barometric damper to by-pass excess air when some of the zones are "off".
The little box with the yellow wires (next to the steam thing) is a sail switch to detect air flow. I won't let the steam flow without air flow.
Old 5/16/07, 10:01 PM
Thanks David
(303) 717-8940
Age of steam boiler needed scoslett Inspecting HVAC Systems 0 3/30/07 8:33 PM
Humidifier supplied by hot water dmull1 Plumbing Inspections 5 2/26/07 12:59 PM
Steam vent?? brepanshek Inspecting HVAC Systems 5 1/26/07 11:45 AM
Radiator valve, Steam jmerritt1 Inspecting HVAC Systems 0 5/31/06 3:28 PM
Humidifier???? dmacy Inspecting HVAC Systems 2 5/24/06 2:19 PM
