Old 4/13/11, 11:31 AM
John Gromkoski's Avatar
John Gromkoski John Gromkoski is offline
Default steam pipe as heat source?
Did a recent inspection in a house with a steam heating system. Boiler is located at the basement level. Basement is living space. There are no radiators at the basement level. The only heat "source" in the basement are the steam pipes that run across the ceiling of the basement. They were boxed out in bulkhead with a grill at the bottom presumably to allow heat into the room. Are these steam pipes considered a "heat source"? My senses tell me this is inadequate but would like to hear other opinions on this.
774 Manor Road
Staten Island, NY 10314
718-514-3393
Need a home inspection in Alabama? Check out InterNACHI's listing of Alabama certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/13/11, 12:03 PM
James H. Bushart's Avatar
Default Re: steam pipe as heat source?
If the temp can reach 68(F) during the heating season it is okay.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 4/13/11, 8:12 PM
Not sure if it can or will. Unfortunately this was a rental property and the landlord had the thermostat locked in a protective box and I couldn't access the darn thing so I wasn't able to activate the heating system. There was a plug in electric heater downstairs which makes me wonder how effective the steam pipes were.
774 Manor Road
718-514-3393
Old 4/13/11, 8:17 PM
Code books, for what they are worth, do not specify any certain type of heating system as long as it will maintain a temp of 68 F during the heating season.
Write it up that you were unable to test it due to its being locked and recommend that it be evaluated by a licensed HVAC tech prior to close of escrow.
James H. Bushart
314-803-2167
Old 4/13/11, 8:35 PM
That's pretty much what I'm going to say. How old do you think this boiler is. House was built in 1905 in case you were wondering.
774 Manor Road
718-514-3393
Old 4/13/11, 9:40 PM
James E. Braun, CMI's Avatar
1905
Was I right? What did I win?
Braun Inspection Consultants
Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
Old 4/13/11, 9:42 PM
Jeffrey R. Jonas's Avatar
http://www.burnhamboilers.net/
http://www.usboiler.burnham.com/
Old 4/14/11, 4:36 AM
You might be right if Burnham boilers were around that long.
774 Manor Road
718-514-3393
Old 4/14/11, 5:21 AM
Linas Dapkus's Avatar
Linas Dapkus Linas Dapkus is offline
That boiler is probably insulated with asbestos which is no problem as long as it's not disturbed. What I find in a lot of old homes is that the insulation on the pipes is damaged or missing. If it's missing or non existent as you describe, was it properly abated or are those boxed out pipe chases contaminated?
Old 4/14/11, 11:23 AM
Michael Larson's Avatar
Lacking any effective heat exchangers or fins on those pipes in the basement, it's doubtful they would provided sufficient room heating capability to maintain 68 degs.
YMMV
Michael Larson
Hudson, WI
Old 4/14/11, 11:52 AM
agallatin agallatin is offline
Question that would make some difference , is the basement used for living space ? If so then for sure it should have proper heat source . Example a bedroom &/or bathroom .
galaxyhomeinspections.com
An amateur built the Ark !
Professionals built the Titanic !
Old 4/14/11, 12:45 PM
Jeffrey R. Pope's Avatar
The temperature has to be maintained at 36" above the floor. A steam system may heat well, but if it's close to the ceiling, it may not provide adequate heat at that point.
Additionally, if the basement is not considered to be "habitable," it doesn't require a heat source.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 4/14/11, 5:45 PM
It was definitely a habitable space, bedroom, kitchen, bath, etc.
I agree with all of your comments guys. Definitely asbestos wrapped, probably won't provide sufficient heat at 36" above the floor, and I was sure to tell my client that the heat source was questionably adequate.
774 Manor Road
718-514-3393
Old 4/14/11, 8:03 PM
Charley L. Bottger's Avatar
Ya guys are wondering if the pipes will warm the basement what about excess heat no way to control that just saying
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Building Science- research from respected sources Brian A. MacNeish Ancillary Inspection Services & Additional Topics 17 7/12/11 6:31 AM
Radiated Heat dhuxted Interior Inspections 31 10/3/10 1:49 PM
Pellet stove help chellickson General Inspection Discussion 23 8/19/10 1:23 AM
Heat pump thermostat jfunderburk Inspecting HVAC Systems 24 10/24/09 5:30 AM
Heat source required in bathrooms menser Inspecting HVAC Systems 7 7/13/06 12:57 PM
