Old 5/21/07, 8:06 PM
nwagner's Avatar
nwagner nwagner is offline
Default Stepped Chimney Span
I encountered this chimney span in an attic yesterday. As you can see in the picture, the mortar joints are very sloppy and contain gaps. Stating the obvious, I found this chimney lacks a flue liner from the roof top and from seeing straight through the mortar gaps with my flashlight. The chimney is composed of concrete block in the basement and along the entire roof protrusion span and it serves a boiler heater.
Old 5/21/07, 9:30 PM
Shawn Rowe's Avatar
Shawn Rowe Shawn Rowe is offline
Default Re: Stepped Chimney Span
I see this type of corbeling on a lot of the older homes I do. I bet that wall isn't 12" thick and I bet that the projection is more than 1/2 the wall thickness. ..... probably would not meet current NFPA standards.
Shawn Rowe, CMI
HomeFirst Inspection Services, LLC
- InfraRed Specialist (Level 1 & Building Science certified)
- Code Certified Residential Building Inspector
- Certified Master Inspector
-- Serving NE Florida, St. Johns, Duval, Flagler, Putnam counties --
Old 5/24/07, 5:13 PM
nwagner's Avatar
Are there guidelines for acceptable chimney corbeling when everything else is in order, such as tight mortar joints and a functional flue liner?
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 8:10 AM
Floating Chimney Syndrome mcyr General Inspection Discussion 8 7/24/07 11:49 PM
Fireplace Enclosure jpope Interior Inspections 19 10/25/06 5:08 PM
Chimney problems mroe Inspecting HVAC Systems 13 3/30/06 9:14 PM
