gfitzgerald is a non-member guest and is in no way affiliated with InterNACHI or its members.
New Construction Condo, 26 units all the same drains inside upstairs hall with hardwood floors
| Need a home inspection in Tennessee? Check out InterNACHI's listing of Tennessee certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Secondary drain?
Yes but I still think you might need to keep a bucket under it
They did save 20Ft. of PVC , the panel you see with the filter is also the only access to the attic. I have a couple more very interesting photos I will post later
Holy Crap.
Greensboro Home Inspection Providing home inspections in Greensboro, High Point, Burlington and the surrounding areas. greensboro-home-inspection.html Raleigh Home Inspection Home inspections in Raleigh, Durham, Cary, Chapel Hill, Apex and surrounding areas. Raleigh-home-inspection.html BassRumors.com Providing a blog, news, and forum dedicated to bass fishing. |
What makes you say a drain ? Did you see where it went ? Could it be a sleeve of some sort ? Or a chase used during construction ? You didnt post this as a question but it left me with some. : )
What makes you say a drain ? A wild guess Did you see where it went ? Yes thats what I get paid for Could it be a sleeve of some sort ? I can't think of any kind of sleeve one would leave hanging in a hall ceiling under the AC Or a chase used during construction ? A chase left in the ceiling of every unit of a building that is finished, I think not. |
What did it drain ? I cant think of a chase or sleeve that would be left to be finished but today some Superintendents are spread thin and I would like to see his face when that question is brought up
Curtis, The drain pan under the AC unit. This building is a POS I don't think they had a super and if they did he was stoned. The buyer walked because of the shoddy workmanship in the whole complex. If you can see this kind of work just Imagen what you can't see.
Gary , I would like to recant my post because I look like a dope .LOL I agree with Larry.
No such thing as a dumb question
They are just following CODE.
Y'all know all about Codes don't you? The secondary must be located in a "conspicuous" location! You can't be calling this one out!? ![]() "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
The whole point of having a secondary drain/pan is to prevent damage to the building if the primary drain fails or becomes obstructed. This does not achieve that, so I would certainly call it out. Might just as well just allow the primary overflow from the coil onto the access cover. If you were being facetious, I apologize for not picking up on the sarcasm... Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX Last edited by cevans; 7/6/10 at 11:54 PM.. |
They all go outside around here and they don't comply with the code. I don't call it out either... Which pipe is which? "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
| Strange Market right now... Call volume very slow!?!?... | jwatts1 | Miscellaneous Discussion for Inspectors | 14 | 8/2/09 10:42 AM |
| Strange history lesson | cbottger | Miscellaneous Discussion for Inspectors | 1 | 3/18/08 2:52 PM |
| Attic shot strange heat??? take a guess | cbottger | Thermal Imaging, Infrared Cameras & Energy Audits | 0 | 1/9/08 5:00 PM |
| Strange shower stall?????-) | cbottger | Plumbing Inspections | 8 | 12/14/07 11:40 PM |
