Old 2/25/10, 5:26 PM
Chuck Evans's Avatar
Default Supply vs. Return Register Placement
New construction in Houston area with conditioned attic space. The attached picture shows the close proximity of the return air duct to one of the supply ducts in the master bedroom (spacing is about 24 inches and they are both somewhat tucked into a corner). Both my client and I think they are too close, but the builder is resisting.
I'm looking for an authoritative source / citation that addresses minimum required separation and what the minimum is. I suspect that it's in the ACCA Manual D, but I don't have it. Any help is appreciated.
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Need a home inspection in New York? Check out InterNACHI's listing of New York certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/25/10, 5:33 PM
Default Re: Supply vs. Return Register Placement
Crank the heat way up and break out you IR imager...
Larry Kage, CMI
231 929 3525
Old 2/25/10, 7:03 PM
James F. McKee's Avatar
that should do it....
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 2/25/10, 8:07 PM
Bob Elliott's Avatar
I do have a file somewhere as this issue came up for me last year.
Till then ,I am pretty sure it is wrong.
Will post when found.
Old 2/25/10, 8:58 PM
Matthew K. Klein's Avatar
Matthew K. Klein Matthew K. Klein is offline
From what I can see, the louvers on the diffuser are aimed away from the return grille. In which case, the supply air should be blown away from the return. In fact, blowing air away from the return could enhance the air flow toward the return.
In general, though, all diffusers have throws that are vary with supply air flow. The throw is the distance the air will flow before reaching a terminal velocity of 50 fpm. In designing supply air systems, the goal is not to have the return air opening toward the outer edge of the throw. That means that the supply air diffuser is usually placed as far away from the return as possible. That being said, one manufacturer used to make a supply air diffuser that had the return in the middle of the diffuser. The theory was that the movement of the supply air helped pull air toward the return air opening. I believe it didn't succeed because of the logistics of installing the diffusers.
I will also add that no matter how return air diffusers are designed, they usually do not work as designed. The only ones that have a chance of working right are ducted ones. Even then, most of these systems are not balanced, and return air systems need to be balanced just as supply air systems do.
Matthew Klein, P.E., M.B.A.
Criterium Engineers
PO Box 181503
Cincinnati, OH 45018-1503
Phone: 513-474-9600
FAX: 888-747-0427
E-mail: Criterium-Cincinnati@fuse.net
Website: www.Criterium-Cincinnati.com
Old 2/25/10, 9:59 PM
Banned
SHEESH!!!! All that is needed is common sense!! Try the analogy of a short circuit in an electrical circuit. The power isn't getting where it needs to be.
In this case, the conditioned air is not getting where it needs to be.......it's being short-circuited back to the return. Try using a bit of smoke from a smoke pencil when the system is running.
Old 2/25/10, 10:57 PM
Michael R. Boyett's Avatar
Chuck, are you sure that return air grill is ducted to the AHU? It might just be a transfer or jumper duct to a nearby hallway to help equalize pressure and allow a path for air to get back to a hall and eventually a return when the door is closed to that room. If so, then I wouldn't think the location shown would be an issue. If it is ducted to the AHU then take a look at this document.
2004_09TechTalk_ReturnGrillLocations.pdf
Old 2/25/10, 11:16 PM
Russell J. Hensel's Avatar
Russell J. Hensel Russell J. Hensel is offline
thanks michael for the input...
Old 2/26/10, 2:54 AM
Attachment 35241
Thanks Michael. Yes it is an actual return that is ducted back to the return plenum. Not a jumper or transfer duct.
BTW: I did come across this document which is an interesting resource http://www.energy.ca.gov/efficiency/...rocedures.html
I guess one thing that could be done to test the affect that the proximity of the supply to the return may be to place a temp probe in the suspect return duct and another in a non-suspect return duct with the system operating and compare the temperatures to see if the suspect return air temperature is being significantly influenced by the supply (i.e., when the heat is running is the return air temperature inside this duct higher than other return ducts). YES - I know that this goes beyond the normal scope of a home inspection.
Thought I would share another "interesting" duct location from this house. Note the location of the fresh air intake duct in this picture (yes they used an exhaust duct and placed silicone caulk in the louver pivots to hold the louvers open). The intake is placed directly above the hot discharge of the condensing unit (remember this is southeast Texas).
Houston, TX
Old 2/26/10, 6:55 AM
Banned
Attachment 35241
Are there other supply grilles in the room?
If not..........These two grilles are tucked into a small remote corner. There is no way any amount of the supply air, especially if heated, will make it out into the room. IT'S BAD DESIGN.......plain and simple!!!!
Old 2/26/10, 7:43 PM
There is a second supply in this room
Houston, TX
Old 2/27/10, 12:07 AM
I have to wonder if some people do not understand how ceiling diffusers work. If they are designed properly, the air blows out along the ceiling. To get an idea of the air flow pattern for a single throw diffuser, look at Figure 14 in this article: http://www.hdgrant.com/hpacart.pdf. The louver direction dictates which direction the air flows. If you look closely at the photo, you can see that the louvers are aimed away from the return grille. If you look at Figure 14 in the article, you can see that if the diffuser is working correctly, that is designed with the proper air flow for the diffuser, then the return air grille is in an optimal location in the room.
If you want to verify what is going on in the room, use a smoke tube to visualize the air flow. It is probably one of the most under-rated diagnostic tools out there.
Criterium Engineers
PO Box 181503
Phone: 513-474-9600
FAX: 888-747-0427
Old 2/27/10, 11:29 AM
David A. Andersen's Avatar
Example of "throw" (ignore the ceiling leak...).
BPI# 5015804
HELP! What do you call a 3 prong male plug with a cord. gromicko Electrical Inspections 5 1/9/09 12:33 AM
How To Stop Your Home Inspection Clients From Suing You! rray General Inspection Discussion 17 6/4/08 2:22 PM
Water Heater supply and return reversed dosborne Plumbing Inspections 3 8/5/07 2:08 PM
Water supply pipes and drain pipes running through return air ducts? aharper1 Inspecting HVAC Systems 3 9/26/06 12:09 PM
