Coral is a non-member guest and is in no way affiliated with InterNACHI or its members.
I am assuming that running flex gas piping on the exterior of a finished wall, or inside a finished wall, is not code, but I cannot find the code justification for it - can someone please help me with this one? It is yellow flex piping as shown in the attached photo. It connects two ends of a rigid steel gas pipe which eventually feeds a gas range. Thanks in advance for any help on this
jclark1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
From what I've read, it depends on the local jurisdiction. All of the major codes allow it per manufacturers instructions. If it is adequately sized, the correct fittings are used, it's supported and it is not subject to physical damage it should be ok. I'm sure that someone here is more experienced with CSST than me and hopefully can look at your pic and see if there is a problem. Here is a link to a Design and Installation Guide of a major manufacturer of CSST. http://www.gastite.com/include/langu...IGuide2006.pdf
Current construction standards as a guide ("code" is a dirty word for an HI) usually require installation in accordance with manufacturer's instructions, which usually require protection if "subject to physical damage". That last part is usually a judgment call.
JMO Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
Don't forget about the lawsuit regarding CSST piping.
Brian R. Sumpter First Call Inspections Proudly serving most Bay Area Counties www.firstcallinspections.com |
I don't believe the flex gas lines and the CSST are the same animal. Flex has been around since Col Sanders was a corporal. CSST is a relatively newer product.
Cant tell from the pic, but it depends on the brand stamped onto the line.
Just in case someone needs this: CSST consists of a continuous, flexible, stainless steel pipe, and typically is covered with a yellow exterior plastic coating. In the case of one of the products manufactured by OmegaFlex, called "COUNTERSTRIKE," the product is covered with a black exterior coating with yellow lettering. CSST typically is routed beneath, through and alongside floor joists, inside interior wall cavities and on top of ceiling joists in attic space from a gas source to an appliance. Titeflex's CSST product is known as "GASTITE," Ward's CSST product is known as "WARDFLEX," OmegaFlex’s CSST is known as "TRACPIPE" or "COUNTERSTRIKE," Parker Hannifin’s CSST product is known as "PARFLEX." Typically, these products may be visible along floor joists, above basements, in attic spaces, or connected to exposed appliances such as water heaters. The piping should be stamped with a manufacturer’s mark. Brian R. Sumpter First Call Inspections Proudly serving most Bay Area Counties www.firstcallinspections.com |
Here are some pics of the various basic flexible gas piping types (the first one is CSST, the second flexible tubing, and the last an appliance connector). But the bottom line is any flexible gas piping needs protection when "subject to damage" ... even appliance connectors. [P.S. There is also a newer type of flex gas piping similar to CSST with an additional thick outer protective jacket which I understand is rated for direct burrial, but I didn't have a pic of that] JMO Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... Last edited by roconnor; 11/28/06 at 3:44 PM.. |
P.S.S. Note the second pic with the painted yellow flex gas tubing is a good example of how flex gas piping should be connected to a furnace/boiler. Note that the flex pipe does not pass through the equipment knockout, but is instead connected to rigid pipe that projects out.
Running flex gas piping through an equipment knockout is a classic no-no that should get written up every time. JMO Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
apolillo is a non-member guest and is in no way affiliated with InterNACHI or its members.
that 90 degree bend is problamatic.
Anatol...I thought so too until I read Table 4-1 on pg 49 of the Gastite Installation Guide shown in post #2, now I'm not so sure.
I think he was referring to the CSST bend in the original photo, I know I was.
| Do you put polybutylene in the Summary? | jfunderburk | Plumbing Inspections | 36 | 10/27/10 11:21 AM |
| Bonding both hot and hold supply pipes | kshepard | Plumbing Inspections | 22 | 5/4/08 9:00 AM |
| Bonding Piping 101....Good To Know ! | pabernathy | Electrical Inspections | 37 | 4/28/07 12:25 PM |
| Yellow Pages vs Internet vs Realtor | jmckenna1 | Miscellaneous Discussion for Inspectors | 13 | 9/17/06 3:09 PM |
