Figure this one out
Whats that flammable can doing there Charlie.
How many cars you gonna start in the attic? |
If it gets cold enough in Markland that hummifier gonna freeze, the little pipe will burst and water goes everywhere...and other places, too.
That flue is cutting through at an interesting place .
Is that Vermiculite? Also do not care for screw holes for the support strap. |
You guys are not seeing the big picture I sure hope you do a better job of inspecting houses than you do with pictures
Flue touching air duct. Air ducts not properly leaked. Not sure what that black thing is, but it is leaking - stain on the wood. Damaged insulation on one of the ducts
Also,
No work platform, and is that a 'can light' under the insulation in the background? Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Do you see a furnace no work platform required and yes there were numerous canister lights buried in insulation but that is not whatI am looking for thanks for trying but no cigar
Clearance to combustibles was noted and I don't follow your (air ducts not properly leaked) and yes that black thingy was leaking in its past life no longer in use no water connected so no cigar here not what I am looking for.
How about the hazardous material in the green can?
Nope green can is not hazardous it is a empty bug bomb
Better pictures might help some.
Are you just a blind inspector from AZ that is a great pic shows everything you need to see
Sorry Bk I am to hard on you so I am going to tell you the only clue you should have and be able to see the problem.The furnace is a upflow installed within a garage closet
I see torn unsuported ducts going into that abandoned humifier. What else is there??
I see a black iron gas line, and I think a furnace flue butted up next to the duct. |
| Picture with text software? | bforeman | Inspection Hardware, Software & Publications | 5 | 2/16/09 12:24 PM |
| www.FireDoorInspector.org | gromicko | Commercial Inspections | 108 | 1/12/09 2:39 PM |
