Old 12/9/06, 3:47 PM
Andy T. Bishop Andy T. Bishop is offline
Default Tempstar
Can some age a tempstar for me?
Serial # on Furnace
KGA040110283
Serial # on Air
JSA031000633
I tried to google them to look at some info but could not.
Thanks for the help!
Andy B
Old 12/9/06, 4:42 PM
Ted Allen Ted Allen is offline
Default Re: Tempstar
Do you have the model # ?
Old 12/9/06, 6:03 PM
HVAC
Mod # KG6RA 06C-12a
Cent Air
Mod # JS3BA-024ka
Old 12/10/06, 2:47 AM
Russel Ray's Avatar
From your other thread, Andy:
Originally Posted by rray
I'm still compiling information on the newer Tempstar stuff, but everything I have found so far indicates that for the newer serial numbers, you can ignore the first set of letters. So the first one would be January 2001, and the second one would be late August or early September 2000. That second one could be late August or early September of 1984, but I don't think so since the serial number has four letters in the first group. That seems to indicate that it is a much newer unit. The older units had two or three letters in the first group.
Old 12/10/06, 4:15 AM
jclark1's Avatar
jclark1 jclark1 is offline
Please Note: jclark1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
According to C-D's Technical Reference Guide they might be 03 (AC) and 04 (furnace). It says first set of digits are the year and second set of digits is week. Do they look like pretty new units?
Old 12/10/06, 8:59 AM
James
Where did you get this info? I think you are right as the home was built in 2004.
Can you tell what this efficiency rating is on the HVAC?
THanks
Andy B
Old 12/10/06, 9:03 AM
I got nothin'
Old 12/10/06, 9:34 AM
Adam J. Slimack Adam J. Slimack is offline
Andy, sent this to you yesterday...
YESTERDAY - Andy, It looks like 04' on the furnace and 03' on the A/C. Does this make sense by there apparent condition? Logically it does...
In the future, if you are unsure, look at the 'anzi' date and it will usually be a few years added to that. (ex. 'anzi' date - 1991....approximately 93 date of manufacturer) You can play that and the serial #'s against each other and come up with a real solid 'guess'.
TODAY - with the information that 04' is the year built, i would say that confirms it.
Old 12/10/06, 9:42 AM
Thanks Adam.
I don't always look at my P.M.s.
I was trying to see if it was a 90% eff or higher?
How do i find this out?
Thanks
Andy B
Old 12/10/06, 9:50 AM
How was it vented? Metal, pvc, 1-2 pvc lines?
How about the burner area...could you see the burners or were they enclosed?
Old 12/10/06, 11:18 AM
The burners were not closed. They were a manifold. IT had a metal flue going out the roof and two fresh air pipes coming in the room from the outside?
Explain to me the diff between the sealed units and unsealed as to the diff in efficiency?
Thanks
Old 12/10/06, 11:21 AM
Russel Ray's Avatar
The unsealed units will be less efficient because they let more oogy stuff into the burner chamber and let more gases out. A selaed unit has controlled air intake and controlled burning.
Old 12/10/06, 12:03 PM
I agree. But that is why i was trying to find more info on THIS unit to see if it is a 90% eff or how much.
Thanks
Old 12/10/06, 3:37 PM
jclark1's Avatar
Originally Posted by abishop
James
THanks
Andy B
Nothing in the Carson-Cunlop book about model# info (efficiency, btu's etc.)
Help with Tempstar age and size please bracine Inspecting HVAC Systems 1 1/12/07 12:32 PM
Help with tempstar oil furnace age sorofino Inspecting HVAC Systems 1 9/1/06 4:02 PM
