What test can be done on a propane supplied furnance that has no propane?
"I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com |
Turn on the fan...
Yea, turning the fan on was the only thing I could think of
too. "I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com |
At the time of the inspection .................
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
Why bother, it needs to have fuel, to be turned on to check for function. Write it up |
Ditto. How can you inspect it if there is no fuel. All you can report on is any visible condition you see. Then write: have gas company fill the tank and have the system tested by a qualified contractor. Sure does limit your liability.
| Arizona, one day mold cert | dbucknavich | General Inspection Discussion | 4 | 6/26/06 9:32 PM |
