Old 4/13/09, 3:51 AM
David Nasser's Avatar
David Nasser David Nasser is offline
Default Testing HVAC if Temperture is below 60 degrees
I have verbiage that states that the outside temperature is to low
to test AC system. ( to turn on from the thermostat) Does anybody
know the reasoning behind that disclosure ?
David
Find an InterNACHI certified Texas Home Inspector (and anywhere else in North America)
Old 4/13/09, 8:50 AM
David A. Andersen's Avatar
Default Re: Testing HVAC if Temperture is below 60 degrees
A/C (not heat pumps) are not set up to run in cold temps.
1. They do not have wide ranging metering devices. They also do not have an accumulator to catch liquid refrigerant before it makes it to the compressor (like a HP does).
2. There is no load indoors to use up the liquid refrigerant. It is also cold outside so low head pressure causes the system to starve.
3. They don't have an immersion heater in the compressor.The refrigerant migrates into the oil when cold outdoors a not used for a while. At startup the refrigerant (and the oil with it) is pumped out of the compressor. Oil may damage the compressor.
For a compressor to be efficient, there must be little clearance between the compressor piston and the head. Any liquid getting in there will break a valve or crankshaft.
If you do run it in the cold, It wont run right for you to tell anything but that it runs.
It can be modified to operate in the cold (by an HVAC engineer) so it can be tested, but you can't.
BPI# 5015804
Old 4/13/09, 8:07 PM
Thanks
Old 4/13/09, 9:11 PM
Hope that helped.
Had to be brief, leaving for work...
BPI# 5015804
Old 4/14/09, 12:44 AM
Wade Williamson Wade Williamson is offline
Thanks for the very detailed explanation. I have had the same question.
Wade Williamson
Axium Inspections
Colorado Home Inspection
What is your HVAC procedure? sstowe Inspecting HVAC Systems 66 5/28/09 1:48 PM
Well Water Testing in Coeur d’Alene, ID 83815 rspriggs Ancillary Inspection Services & Additional Topics 0 1/9/09 4:31 AM
980 Questions/Answers to the NHIE....Free! jbushart Legislation, Licensing & Legal Issues for Inspectors 50 4/20/08 2:26 AM
Moisture in slabs mcyr Structural Inspections 7 8/20/07 8:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 11:26 PM
