Old 5/25/11, 9:30 PM
Dale Young's Avatar
Dale Young Dale Young is offline
Default Thermostat?
Did an inspection in a house w/older gas furnace; when i got to the thermostat it listed as "for electric furnace only". Why gas furnace with for electric furnace only or i am making something out of nothing? Appreciate any help.
thermostat-2011_0519396crestview0182.jpg   thermostat-2011_0519396crestview0128.jpg
Dale Young
Young & Son Home Inspection Service
601-431-3551
www.younghomeinspection.com
Need a home inspection in Oregon? Check out InterNACHI's listing of Oregon certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/25/11, 11:54 PM
Charley L. Bottger's Avatar
Default Re: Thermostat?
Probably has to do with the heat anticipator the amp draw of the gas valve should match the thermostat anticipator if it has one. That old gas furnace in your pic would have a 24 volt gas valve, no milivolts they were used on floor furnace gas valves. If the furnace cycled on and off with the thermostat I would not be concerned.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 5/29/11, 11:35 AM
Gary Reecher Gary Reecher is offline
Send a message via Yahoo to Gary Reecher
Please Note: Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
Electric furnace thermostats are set up to energize the fan relay on a call for heat as well as call for cooling. If there is no air conditioning then the fan circuit would not be wired in.
I am more concerned with the staining around the burner cover indicating that there is a possible venting problem or a possible leak in the heat exchanger causing combustion gases to spill slightly when blower comes on.
Old 6/1/11, 12:48 AM
Dale Young's Avatar
So noted. Scorning was noted; aswell as corrosion on the vent pipe; serious issues were brought to the attention of the client. Thanks!
Dale Young
601-431-3551
Thermostat Recall Shock Hazard Gary Reecher Inspecting HVAC Systems 0 7/22/09 6:05 PM
Thermostat dead sshockley Inspecting HVAC Systems 1 7/22/09 5:45 PM
Baseboard heater + Thermostat Question. jkogel Electrical Inspections 3 5/7/08 10:30 AM
Thermostat location kweiss Inspecting HVAC Systems 13 8/30/07 2:38 PM
