Raymond Marsh is a non-member guest and is in no way affiliated with InterNACHI or its members.
I have a new construction home and have always wondered about the location of the thermostat. It was placed in a small alcove in a hallway connecting the living room / kitchen / dining to the bedrooms. It seems like a good spot, centrally located and right by the return air, but I have read a lot of bad things about placing it in an alcove like this.
There does not seem to be any consistency in room temp. Some days I have to put the stat on 72-73 just to be comfortable, other days that is just way too cold. There also seems to be some humidity problems from time to time. If you look at the attached pictures, the only thing in that alcove is a bath and a closet, and both doors have to stay closed. I am some what knowledgable with HVAC systems, but am in no way an expert, so I thought I would ask the opinion of some professionals. It seems to me that the stat is not accurately reading the temp of the return air as maybe the air is passing right beside the stat instead of past it. Of course I could be wrong. Thoughts? |
How large is the home
Gary Porter GLP's Home and Mold Inspections 321-239-0621 Certified Commercial Mold Inspector Serving Orlando, Kissimmee, Winter Park, Winter Springs, Oviedo, Titusville, Celebration, Harmony, Avalon, Windermere, Deltona, Debary, Sanford Orange County, Seminole County, Volusia County, Osceola County www.homeandmoldinspections.com |
Since there are problems with the heating and cooling, and the thermostat is located where it gets little exposure to return air, and the only exposure it gets is return air from a bathroom which may be extremely warm sometimes, I would recommend relocating it to the wall with the lightswitch.
Raymond,
Looks like a centrally located filter-grill type? Is this the only R/A-F/G designed into your HVAC system? Are ther others? Are you having airflow problems to all rooms, or just the furtherest/perimeter rooms? Do you know if any of the existing supply ductwork (attic area location?) has balancing dampers in any of the runs? Is the alcove area open in all directions or can it be closed off, and do you close it off? With limited info., it sounds like you may have more of a balancing/airflow problem than anything else, but again limited info. to work with. If this is a new home (say within the 1st year warrenty), I'd call the Builder and/or the installing HVAC Contractor. Check with your neighbors, they may be having the same problems you are. Good Luck |
Look for an open area, on an inside wall, somewhat away from the return duct.
Also, how often do you change your filter. Should do it every 30 days. Hope this helps; Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
rdawes is a non-member guest and is in no way affiliated with InterNACHI or its members.
Another good resource for HVAC answers is http://hvac-talk.com. Post in the Residential section and you'll get a ton of answers.
Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
Another option versus cutting off the bottom inch of the door is placing transom grilles in the walls of the rooms. Place one low in the room and one high in the hallway in the same stud space. Tjernlund also makes a powered transom system called AireShare
| Thermostat location | kweiss | Inspecting HVAC Systems | 13 | 8/30/07 2:38 PM |
| Any good checklist for HVAC | cgoyette | Inspecting HVAC Systems | 3 | 8/1/07 3:32 PM |
| Service swith turns off thermostat | ccbrands1 | Inspecting HVAC Systems | 6 | 1/27/07 5:15 PM |
| Red "Check" light on Carrier Thermostat | Skip Erwin | Inspecting HVAC Systems | 10 | 12/29/06 5:50 PM |
| A/C location of expansion device vs line temps. | bking | Inspecting HVAC Systems | 9 | 5/29/06 4:16 PM |
