What's wrong, missing, not working?
| Need a home inspection in Idaho? Check out InterNACHI's listing of Idaho certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
NEW RETURN TRUNK DESIGN EXTENSION
I have never seen this in SSM On. I think you are missing the return to some area not served on that direct return plenum. Purhaps an office or addition added. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
Not enough info
Charley, I don't want YOU spilling the beans!!!
OK, Hint... Supply air pressure 97 pa. (97 pascal = 0.389 419 186 31 inch of water [4 °C]) Turn off 2nd floor thermostat and pressure goes to 179 pa. 179 pascal = 0.718 618 910 81 inch of water [4 °C] 75pa = .3" wg ; residential system design duct pressure (static). "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission Last edited by dandersen; 5/5/11 at 4:04 PM.. |
What are you showing in the first picture other than a couple of plenum/duct takeoffs? Still not a great picture in the second photo.....I'm thinking a duct damper control arm.....but in the return? Last edited by Brian A. MacNeish; 5/5/11 at 6:41 PM.. |
Pretty common here in residences over 35K
Do you mean 35,000 ft2 or 3,500ft2?
I can see it being used in cooling climes.....need to get that cooling upstairs. Predominantly heating climate here- 95%+. I used to see it in larger 1950-1960's homes and in the odd other one......but we haven't had much cooling in houses here until the last 5-10 years......HP/AC units being seen more and more. |
Hows the filter?
House is 2,563 sf.
Cat 4 with 3 thermostats. Had a damper controlled vent to the garage to boot. |
Was it listed as a fire-damper?
I find thermostatically controlled dampers in homes of all shapes and sizes. The dampers, however, usually include control boxes and balancers IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
[ATTACH][ATTACH] [/ATTACH][/ATTACH]http://www.nachi.org/forum/f20/garage-question-60368/ www.chicagopropertyinspection.com www.elliotthomeinspection.com www.chicagolandhomeinspection.com www.homeandcondoinspector.com www.homeandcondoinspection.com http://www.homeinspectorpro.com/ (Report Software) Bob Elliott http://www.chicagolandhomeinspector.com/ Last edited by belliott; 5/6/11 at 1:58 PM.. |
[quote=Brian A. MacNeish;780005]Do you mean 35,000 ft2 or 3,500ft2?
/quote] 3500Sq Ft My Bad was in a hurry Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Jeff & Bob, you both posted pics of the missing parts...
I don't recall that, but the duct to the garage would require a listed smoke-and-fire damper in my jurisdiction.
| Supply vs. Return Register Placement | cevans | Inspecting HVAC Systems | 12 | 2/27/10 11:29 AM |
| Critter in the return air duct... | swaskewicz | Inspecting HVAC Systems | 11 | 11/28/07 3:49 PM |
