Wait till you see one of these new units I saw at the home show today it will blow your mind as to what you might think you know. Even I did a double take. It is so new they would not allow me to take any pictures yet.
This unit is to be included with a green package that this builder is putting together to try and get a Star rating above green. Referred to it as Green +. This A/C unit that I was looking at has four liquid lines and four suction lines and two water lines entering the unit. It actually is a geo heat pump but with all of these lines extruding the cabinet. Each line has a liquid line solenoid valve installed and is controlled from head pressure of the unit. Kind of complicated to the novice. I did not have time to get all of the pictulars but will be getting back with the builder as he wants me to do IR on his new constructed homes for advertising purposes. I will be posting Pictures of this unit when they allow me to take them. I don't think many Hi's will be running into this unit as there is only one installed in the U.S. at this time Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Thank goodness for this:
I. The inspector shall inspect:
A. The heating systems using normal operating controls and describe the energy source and heating method. Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
They running a 4-circuit evaporator coil, or 4 evaporators in different zones? |
I like new gadgets and new equipment. Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Trane has a unit that hasn't hit the market yet that will be "heat pump for dummies". You charge it with liquid only, and it has an LED light that goes off when the charge is correct. Oy vey. |
Please take and post some pics! ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
What was the brand?
I saw an unusual model from Taiwan the other day in a three story townhome. It worked. But the thermostat was so UNintuitive, it was all I could do to turn them on. Had the one outdoor unit and 3 seperate indoor units controled by three thermostats. Appeared to be more conventional than what you describe. As far as I could tell the insulated cooling lines were plastic. |
Energy source would be electric and/or gas, and heating/cooling may be refrigerant and/or geothermal.
Should be interesting. I'll add it to the AC course CD when more info becomes available. |
National Sales & Southern zone office 1645 Wallace Dr, Suite 110, Carrollton, TX 75006, U.S.A. Phone: +1-972-245-1510 Fax: +1-972-245-1038 ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
| Room size requirement for HVAC supply | kweiss | Inspecting HVAC Systems | 3 | 6/9/07 6:58 PM |
| Access to Electrical Panel in Ontario by HVAC Contractors | Nalliah Thayabharan | Canadian Inspectors | 10 | 5/21/07 3:01 PM |
| Condemned Furnaces Spark Safety Issues | Gary Reecher | Inspecting HVAC Systems | 7 | 3/8/07 8:17 PM |
| HVAC..definitely my weakness..any help? | tneumann | Inspecting HVAC Systems | 3 | 1/30/06 5:37 PM |
