A Client actually acted on the report recommendations correctly and even hired his own HVAC inspector instead of using one hired by the seller.
Actually the seller refused to hire one since the systems "operated". I bet they wish they had hired their own tech now. I also advised the client to make sure he got one that was capable of measuring airflows. Here are the actual findings from the HVAC techs inspection after he had access to my report: Upstairs System 1 a piece of insulation is missing off of the suction refrigerant line in the attic, need to re insulate it $25 2 the main drain line for the air conditioning is pitched the wrong way just after the p-trap, need lower the strapping and re pipe a section of the drain line $ 35 3 air leaks on the cased evaporator coil around the refrigerant and drain lines, need to seal the air leaks $25 4 the blower capacitor is rated at 7.5uf + or - 6% and is at 6.9uf this is below the manufactures recommend tolerances, need to replace the capacitor $165 5 the refrigerant lines have a rise of over 20' according to the manufacture there should have been a crank case heater installed as an accessory to keep the compressor oil warm and to keep the refrigerant for migrating back to the compress when it is off so it does not cause the compressor to struggle starting with liquid refrigerant in it, need to install a crank case heater $125 6 the filter being used in the house is too restrictive on air flow and is causing higher static pressure in the ducts, filter media should be no higher than a MERV 8 Downstairs System 1 air leaks on the cased evaporator coil around the refrigerant and drain lines, need to seal the air leaks $25 2 there is no secondary drain install on the evaporator coil this is not required by code but if the main drain line ever backs up water will overflow into the duct work and ruin the duct, need to install a secondary drain safety float switch to shut the system off before it overflows $125 3 the pressure safety switch for the furnace was never properly rerouted and extended for a horizontal left installation application this could cause nuisance trips of the safety switch or cause the safety switch to malfunction, need to get extension tube and re route it according to the manufactures specs $65 4 the fresh air pipe and cap for the furnace were glued and fresh air screen was not installed can not install screen due to is being glued in place it should have been screwed in place this will also hinder the access to the hot surface igniter if it ever needs to be replace, need to install a new housing and screen for the fresh air and re pipe $ 175 5 a coupled supply duct is laying on the ground, need to re hang duct with strapping $25 6 the liquid line service valve is missing a cap, need to install a new cap $25 7 the air conditioning system is a little bit low on freon I did a leak search and did not find any leaks at this time I believe the system was never properly charged with freon, need to *** 1lb of R-22 refrigerant $82 8 the filters being used in the house is too restrictive on air flow and is causing higher static pressure in the ducts, filter media should be no higher than a MERV 8 9 several of the flex ducts were not properly install at the collars on the trunks they are leaking air and the vapor barrier and insulation on the flex duct was not properly pulled over the collars this is causing the metal collars to condensate and also getting heat gain and heat loss, need to pull the vapor barrier and insulation back and seal the collars, properly reinstall the vapor barrier and insulation over the collars and seal the vapor barrier to the trunks, $450 10 after performing the heat load calculation and measuring the air flow we determined the all the ducts are sized properly and the air flow from the furnace is correct however there were three rooms lacking air flow the rooms are the great room, office, and the guest bedroom, need to air balance the duct system $850 B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
| Need a home inspection in Massachusetts? Check out InterNACHI's listing of Massachusetts certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Jeez talk about Jessie James without a gun those prices are crazy $165.00 to change out a $10.00 run capacitor $450.00 to seal up some duct and $850.00 for a air balance I should not have retired
LOL i was thinking the same thing Charlie, He must have been the ac guy for the stars .
| Inspecting Furnaces. Please proof this new inspection article. | gromicko | Inspecting HVAC Systems | 4 | 9/15/09 9:54 PM |
| 3 days left for HVAC discount | bgromicko | Miscellaneous Discussion for Inspectors | 0 | 3/28/09 10:36 AM |
| Access to Electrical Panel in Ontario by HVAC Contractors | Nalliah Thayabharan | Canadian Inspectors | 10 | 5/21/07 3:01 PM |
| Condemned Furnaces Spark Safety Issues | Gary Reecher | Inspecting HVAC Systems | 7 | 3/8/07 8:17 PM |
