I saw this on an inspection yesterday. It looks like batt insulation installed inside the vents. Any thoughts on this will be greatly appreciated
This property is a renovated former officers quarters at a former Air Force Base. Thanks Jonathan Jonathan N. Leahy President A Rock Solid Home Inspection, LLC. www.arocksolidhome.com 303-718-7779 Residential Home Inspections, Radon Testing, Mold Inspections |
| Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I guess my first question would be, is it currently in use, or has it been abandoned? If it is in use, I would suggest it be cleared of all obstructions that may be in the ducting.
I guess someone didn't understand that even if you block the vent off the combustion make up air will come through every crack or opening in the home anyway. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Thanks all,
I appreciate the feedback. Jonathan Jonathan N. Leahy President A Rock Solid Home Inspection, LLC. www.arocksolidhome.com 303-718-7779 Residential Home Inspections, Radon Testing, Mold Inspections |
| Need thoughts, low water pressure issue. | mroberson | Plumbing Inspections | 4 | 8/1/09 1:26 PM |
| Any thoughts on this???? | acassady | Plumbing Inspections | 11 | 5/10/09 10:38 PM |
