Found a home with three appliances into one chimney. One oil fired heating burner and two LP fired hot water tanks.
| Need a home inspection in Arkansas? Check out InterNACHI's listing of Arkansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
The question on the three into one, is it at all acceptable? This is in the state of Vermont.
Hi Robert,
Hope this isn't too late, but this setup does have problems. The smaller BTU units need to join the flue as far "up" as possible compared to the larger flue of the boiler. This setup does have them technically above the boiler, but the fact that they join into the larger diameter vent like that, which, judging by the pic has no incline to it, bothers me. I'd call it out. (I'm up in Moretown, btw) Is that an LP boiler? The damper makes it look like an oil unit... Tim |
INSPECTIONLOGOS.COM "I can keep explaining it for you, but I can't understand it for you". Nick G. Monroe Home Inspection Last edited by rsmith24; 2/8/11 at 7:55 PM.. |
So what did you end up telling them?
INSPECTIONLOGOS.COM "I can keep explaining it for you, but I can't understand it for you". Nick G. Monroe Home Inspection |
Right you are. I didn't mean boiler. Just had it on my brain from something else...
Tim |
| Oversized Water Heater Flue? | krigler | Inspecting HVAC Systems | 14 | 2/19/10 1:05 PM |
| Coming soon. Free, online, fireplace and chimney inspection course. | gromicko | General Inspection Discussion | 15 | 12/14/09 4:19 PM |
| What's Inside A Chimney | mcyr | Inspecting HVAC Systems | 14 | 9/17/08 6:11 PM |
| Flue Size when size matters? | msylvester | Inspecting HVAC Systems | 14 | 1/20/07 11:29 PM |
