When I'm checking and testing air conditioning units, I like to report the tonage of the unit I sometimes cannot figure that out. Any help would be appreciated? Jim.................
Jim, what method do you use now? You can usually decipher it from the model number or you can purchase a $95 Preston's Guide that will help in many cases.
Michael, thank's for the response. I had forgot about Preston's manual. Will probably not get it at this point because of the cost. But it would be a helpful tool.
Yes, I do try to figure the tonage out from the model#. For the most part that work's, but I was just looking for another method. Tonage is listed on my report and for that reason I like to list it. If I'm not sure, I state it. Jim............. |
James,
Usually in the model number there is a number that is a multiple of 12. 36 is 3 ton 42 is 3-1/2 ton 48 is 4 ton, etc Linda |
You can tell by the size of the liquid line (smaller and warm) and/or by the amperage rating.
Raymond -
Although I teach HVAC classes, I've never had anyone say they could tell the size of the HVAC unit accurately by the size of the freon line??? Expand on this please. |
jeffghooper is a non-member guest and is in no way affiliated with InterNACHI or its members.
Boy, that would be a tough one. I have never heard of that either. In fact, all of our units between 1 and 5 tons have exactly the same size lines.
But then what do I know, Certified Mechanical Inspector is only one of my hats. |
Dan,
That is what I was taught. I will try and find the info. Are the liquid lines all one size? |
There's also the RLA # that would help on getting an approx size
pcarter-old-04 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Raymond,
I am curious about your statement, do you use O.D. Caliphers to determine the sze of the line? Anyhoo, I thought you guys up in Canada did'nt require A/C or do you require it because of all the hot air blowing out of the states? |
The numbers on the compressor and make will tell you the compressor capacity.
Name plate amperage rating can be an indication, not the actual running amps, as Gerry said.
1 HP = 1 Ton refrigeration work. If you know what a 1 HP motor requires, I guess it would get you close. There are different efficiency motors, so all will not be the same. |
Ive heard/read too that the LRA and the RLA could be used to determine the tonnage but found it to be at best a swag, particularly with today's newer equipment. I first saw this method in Norman Becker's (page 219) book on home inspections. As previously stated the best method is by looking at the model number. This can be difficult / impossible at times if the data plate or tag is faded, missing or painted over.
Dan et al:
Upon looking at my info, I have got it backwards... so I stand corrected. Here is what I was taught. Its the suction line not the liquid line size that can help in determining tonnage. 7/8 = 5 ton 5/8 - 3/4 = 3 ton 3/4 = 4 ton 5/8 = 2 ton other info that may be an indicator... Cable size Amps Tons 6 ga. 50 5 8 ga. 40 4 10 30 3 12 20 2 9 amps per ton 12,000 btu/per ton. FLA 7-7.5 = tonnage RLA 5.5-6.5 = tonnage Thanks for catching my goof. Last edited by rwand1; 7/16/06 at 11:47 AM.. |
| wire gauge / breaker rating | jweinberg | Electrical Inspections | 19 | 7/16/06 4:36 PM |
| Need Assistance on A/C Unit | pcarter-old-04 | Inspecting HVAC Systems | 9 | 6/21/06 7:23 AM |
| how do i verify my age and tonage og a carrier unit | mbutler | Inspecting HVAC Systems | 8 | 6/12/06 3:50 PM |
| Adding a A/C unit | abishop | Inspecting HVAC Systems | 20 | 1/18/06 1:39 PM |
