Old 7/3/08, 11:04 AM
Michael H. Butters Michael H. Butters is offline
Default Tonnage
How many square feet can each ton of airconditioning cool?
Michael H. Butters TREC #7021
North Texas Residential Inspections, Inc.
ICC Member
TAREI Member
Old 7/3/08, 11:48 AM
Michael R. Boyett's Avatar
Default Re: Tonnage
In central Texas, I use a real rough rule of thumb, depending upon the age/construction/etc (i.e. perimeter of house in lineal feet, #stores, type of & thickness of insuation, type of windows and doors, direction the house faces, size of duct work, number of occupants) of the home, of 450 sf to 700 sf per ton. If asked, I make sure the client knows only a qualified HVAC contractor should be used to perform a Manual J or other load calculation for an accurate answer.
Old 7/3/08, 12:24 PM
Default Re: Tonnage
Thanks Michael;
I really appreciate the help. And i'll be sure to cover my butt with the caveat.
ICC Member
TAREI Member
Old 7/3/08, 2:42 PM
David A. Andersen's Avatar
Default Re: Tonnage
That is totally an "unknown"!
That may be how it was designed, but is not "how it should be designed"
I get calls from Realtors/Builders/Sub-contractors that ask; "why are you the only one that says that this is wrong..."?
Just because everyone dose it wrong, does not make it right!
BPI# 5015804
Old 7/3/08, 2:47 PM
Default Re: Tonnage
Tonnage is determined by finding how many Btu's/hr must be removed from the area served to maintain indoor design temperature under prescribed outdoor weather conditions and internal load estimates for that particular city.
If you have a quick way of determining this, you have the answer to your question. There is no quick way, so there is no answer I guess.
BPI# 5015804
Old 7/3/08, 4:27 PM
Default Re: Tonnage
David's got it just about right.
"Rule of thumb" works well if you're cooling your thumb...otherwise, actual calculation is the best rule.
Old 7/3/08, 10:10 PM
Scott Gilligan,  CMI's Avatar
Scott Gilligan, CMI Scott Gilligan,  CMI is offline
Send a message via AIM to sgilligan1 Send a message via MSN to sgilligan1 Send a message via Yahoo to sgilligan1
Default Re: Tonnage
Here is a very easy tool to figure out th appropriate tonage.
http://www.hvaccomputer.com/hvac/sizer.asp
Old 7/3/08, 10:43 PM
Default Re: Tonnage
Yup, I have that one in my flip book as "how the other guys do it"!!!
I should put that on my web site!
BPI# 5015804
Old 7/3/08, 11:31 PM
rshuey rshuey is offline
Please Note: rshuey is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Tonnage
I laughed pretty hard....thank you!
Old 7/5/08, 7:28 AM
wsiegel wsiegel is offline
Default Re: Tonnage
There are many factors that go into determining the tonage needed. A Manual J calculation is the only real way to know how many tons you need for a home.
Old 7/5/08, 6:11 PM
sbenson sbenson is offline
Default Re: Tonnage
rough estimate 1 ton per 450 - 700 sq. but as a NACHI memeber are you to calculate or report this, Check out NACHI SOP 2.5.II.A. Inspector not required to determine (size, capacity, BTU)
Old 7/5/08, 7:56 PM
Brian E. Kelly's Avatar
Default Re: Tonnage
DON'T GO THERE
Old 7/5/08, 7:57 PM
Default Re: Tonnage
Frigging Brilliant
Age and tonnage of very old Sears AC unit? fbartlo Inspecting HVAC Systems 2 12/31/07 10:56 AM
tonnage? five.five Inspecting HVAC Systems 29 5/22/06 6:58 PM
