Old 11/17/07, 12:54 AM
Default How toxic is furnace/boiler condensation?
Last week's home had a condensation pump with a hole leaking fluid all ove the floor. I called a vendor out of the yellow pages who told me that condensation is mostly water and non-toxic.
Any comment on this?
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 11/17/07, 1:37 AM
Brian E. Kelly's Avatar
Default Re: How toxic is furnace/boiler condensation?
What did it taste like?
Old 11/17/07, 6:47 AM
Barry Adair's Avatar
Non-toxic like the guy said......................whatever that tastes like???
I'm pretty sure if you had some analyzed it would come back HOT for something.
We (bride and I) were pulling permits yesterday for one of her co. nature centers and the AHJ said, "The condensate now has to directly discharge into a trapped waste line." No more "grandfathering" of the onto soils discharge, but they do allow secondary.
This may or may not be a clue, ya think?
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 11/17/07, 7:03 AM
http://www.engext.ksu.edu/ees/henergy/space/furnaces.html#septic
From above site:
"Is the condensate from a high-efficiency furnace harmful to a septic system?
It's unlikely that a healthy septic system will be affected by the water condensed from the flue gases of a high-efficiency furnace.
A 60,000-Btu furnace operating 50 percent of the time will produce about seven gallons of condensate a day. The condensate has a pH level of about four, which is about the same as a carbonated soft drink. However, furnace condensate is not safe to drink because of trace toxic chemicals it contains."
Larry Kage, CMI
231 929 3525
Old 11/17/07, 8:12 AM
rwand1 rwand1 is offline
I believe the condensate is acidic, about the same alkinity of cola. That is why you sometimes see a tube on the condensate waste line, which contains a neutralizer, as not to corrode waste lines.
Old 11/17/07, 8:17 AM
Roy D. Cooke, Sr's Avatar
Yes and from the AC it is close to distilled water just add a little dust.
..... Cookie
Old 11/18/07, 7:55 PM
William J. Decker's Avatar
Not toxic, but slighlt acidic. No worries, unless you are intimidated by Al Gore
Hope this helps;
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 11/18/07, 8:14 PM
Ahh, 2 + 2= finally the answer 4
Condensate pan showing flow of condensate towards drain is rusted.
Coke soda spilled on metal/show rust
need for trap on condensate
indirect waste on condensate
All makes sense now. I think
Is the answer not good to drink?
Marcel
Old 11/18/07, 8:16 PM
Put a penny in cola and check the penny several hours later.
Old 11/18/07, 8:23 PM
I know, I collect coins. ha. ha.
Marcel
Old 11/18/07, 8:26 PM
Did you ever wonder what Cola does to the human stomach?
Marcel
Old 11/18/07, 8:36 PM
I don't think cola does anything as stomach acid is very very strong, about the same as sulphuric acid I believe.
Old 11/20/07, 12:19 AM
BINGO !! Raymond, thank you very much, two answers in one.
(303) 717-8940
Old 11/20/07, 6:33 AM
Larry helped too!
Old 11/20/07, 10:14 PM
Yep, buch of good answers on the toxicity of condensation, I didn't mena to slight anyone, thanks to all. I'd been trying to figure out the bulge in the condensation line for a high-efficiency boiler in that other thread and no one had commented. That was the second answer.
(303) 717-8940
Interesting article about mold by litigation. gromicko IAC2 Indoor Air Forum 16 5/5/11 7:48 PM
Toxic Gas in Mobile Homes jbushart Miscellaneous Discussion for Inspectors 0 11/12/07 8:31 PM
Excessive AC Condensation Problem kweiss Inspecting HVAC Systems 8 8/6/07 9:15 AM
Condensation Line Drainage Problem thejnicki Inspecting HVAC Systems 5 2/7/07 10:18 PM
condensation line Rafael Exterior Inspections 8 8/20/06 1:41 PM
