Is this acceptable? Or does it have to always be sloped downward.
| Need a home inspection in Virginia? Check out InterNACHI's listing of Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Always sloped downward so any water that may be beginning to leak (dripping) will flow with gravity, and not collect in the drain line.
See it all the time. Not acceptable...
Jeff.J, must be chopped liver...
The end of that also must be visible for Observation. |
I assumed it is visible, very common in CA., thus my not mentioning it. Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
clambert2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Not allowed to run uphill and the corrugated flexible copper tubing is not allowed either.
http://www.nachi.tv/water-heaters/in...ater-tanks.htm . Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
Do you have a reference for that Charley? I don't like seeing these used as part of the TPR discharge, but I haven't seen anything that would prohibit their use.
You would think there should be an air gap just to see if it is dripping but since it is calif.....
Even in CA, this is an improper installation, so I don't understand your post. To clarify, the termination will generally be on the exterior in this type of set up, so (based on my experience) I'm assuming it's visible. The uphill slope on the discharge is improper, but I'm not aware of any restriction on the type of material that has been used. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
The TPR line inside diameter is not allowed to change/restrict the corrugated Copper line is rated at 3/4 inch yet is has a 5/8 inch diameter therefore restricting flow.
UPC 608.5. Not sure what the CPC cross reference number is but I bet it is the same
| TPRV drain pipe Question | jkeilson | Plumbing Inspections | 5 | 2/17/11 9:37 PM |
| Water heater vent pipe...Question | dnasser | Inspecting HVAC Systems | 4 | 11/27/10 12:59 PM |
| Help - Polybutylene Pipes | Rick G | Plumbing Inspections | 39 | 2/12/09 8:16 AM |
| Plumbing vent Routing Question | kweiss | Plumbing Inspections | 7 | 11/1/06 9:57 PM |
