A Trane split system heat pump, only hvac system installed in a 2100 square foot home. Model # is TWR730A100A1 , manufactured 09/91. I determine this unit to be 2.5 tons, that would be under sized for 2100 square feet. Does anyone have info on this model # to confirm this is a 2.5 ton unit ?
Thanks in advance. |
That would be a two and a half ton unit. To determine whether it is the proper size or not would require a load calculation.
Don't interfere with anything in the Constitution. That must be maintained, for it is the only safeguard of our liberties. Abraham Lincoln www.qualityhomeinspectionsfl.com |
30/12 = 2.5 InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
This inspection is tomorrow, I went by to look at the HVAC this afternoon, the reason I wanted confirmation on the size is because I have never seen a 2.5 ton unit serving a two story 2100 square foot home, if the heat operates my job is done. I will recommend when the unit is replaced, it is 15 years old, the HVAC contractor do a load calculation for proper size of new unit.
Charley, what if the air handler is the variable speed type? Don't these typically have CFM jumpers to choose the airflow?
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
A 2.5 ton unit is too small to cool that size house in any climate.
The overall blower size is smaller in a 2.5 ton system. It was stated the unit was 15 years in age so it may or may not have multi-speed motor and even if it does just not enough push for a two story. As a Hi I don't get into efficiency very often but on occasion I have when I absolutely knew I was right based on my experience. But I will inform my client even if the unit is performing as intended but has to run non-stop because of being under sized or poor duct/return problem. I do not want my client to be surprised and start calling me. I want everything on the table. I consider myself as being on the clients informational TEAM for making purchase decisions Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
In accordance with the Laws of Thermodynamics and general physics, you can not effectively cool two stories with one unit unless it has a balanced zoning system and a return duct to both levels of the house. If the second floor area is above the garage, this problem becomes 400% worse. You will see a lot of this. |
I just can't believe whoever has been living there, hasn't already corrected the probable undersize problem.
I'd look further, determine what size Furnace/AHU, and what size Evap.Coil is existing. I'd for sure recommend that the your Client have a Prof. HVAC Contractor inspect and advise. I am sometimes cynical, but the older, larger unit may have crapped out and the owner/seller may have purchased what ever he could, on the cheap. |
| Heat pump in a 80+ year old masonry house | jskrypka | Inspecting HVAC Systems | 9 | 11/25/06 11:47 PM |
| Installing new heat pump with existing furnace | wlmoss | Inspecting HVAC Systems | 6 | 5/14/06 12:23 PM |
| Question on my heat pump | dbush | Inspecting HVAC Systems | 7 | 3/12/06 1:15 AM |
| Armstrong heat pump -- good or bad? | skipswift | Inspecting HVAC Systems | 3 | 2/13/06 10:17 PM |
| Heat Pump Check list for inspecting | dmacy | Inspecting HVAC Systems | 21 | 2/1/06 1:56 PM |
