Data plate on the unit was missing. A 40 amp breaker was protecting unit, according to panel ledger. Most units max 30 or 35 amps, no? Anyone know for sure?
Thanks in advance. |
| Need a home inspection in Mississippi? Check out InterNACHI's listing of Mississippi certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
without the data plate, it would probably be imposible to know the max fuse requirement (and the age/size of the unit).
most AC units I see require anywhere from 20-40 amp protection. when I run into a missing data plate, I note it in the report. |
What about the air handler. It it probably going to be the same size. If it is a 4 or 5 ton unit many of them will have up to a 60 amp breaker especially with an older 10 SEER unit.
Robert Sole, CMI 407-637-7288 Florida license numbers HI 169 and MRSA 92 Serving the Orlando Florida area including Orange, Seminole, Northern Osceola and Southwestern Volusia Counties. RobertSole@REMinspections.com Check out my blog orlandohomeinspections.info/ REMinspections.com OrlandoHomeInspector.net |
| Defrost Control Board - On Trane XE 1000 | sshockley | Inspecting HVAC Systems | 2 | 2/13/10 9:23 PM |
| HVAC condenser clearances | cfolsom | Inspecting HVAC Systems | 7 | 11/22/07 3:03 PM |
| What is a 'condenser' dryer ?? | rcooke | Canadian Inspectors | 9 | 9/9/07 7:02 PM |
| 1000 brochures for $149 | rmarriott | Miscellaneous Discussion for Inspectors | 0 | 4/24/06 7:54 AM |
