Old 11/7/07, 6:54 PM
mashburn's Avatar
mashburn mashburn is offline
Default Transite pipe??
Was transite pipe made to also be an oval shape?
Ashburn Inspections
724-516-1665
Old 11/7/07, 7:01 PM
ldapkus ldapkus is offline
Default Re: Transite pipe??
I did asbestos abatement for 15 years and never saw oval transite pipe.
Old 11/7/07, 7:04 PM
I installed transite pipe and never seen oval pipe.
Where did you see it and why do you ask?
Marcel
Old 11/7/07, 7:19 PM
mashburn's Avatar
I found it in an 70+ year old home that only the water heater was venting into. I could not get into attic space only form hatch. The texture appered to be the same as the transite I have seen before. I have no picture yet, sorry.
Ashburn Inspections
724-516-1665
Old 11/8/07, 2:18 PM
Charley L. Bottger's Avatar
Yes have seen a ton in my time used primarily in my area for the old wall type gas heaters. I still see some occasionally abandoned and once in a while still in use. Next time I run across some will take a Pic and post if for all of you young guys
</IMG></IMG></IMG></IMG>
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 11/8/07, 2:51 PM
Jeffrey R. Pope's Avatar
I've seen the "oval" shaped Transite vents as well. The same shape of the Type BW steel vents.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Do you put polybutylene in the Summary? jfunderburk Plumbing Inspections 41 4/5/12 6:43 AM
Help - Polybutylene Pipes Rick G Plumbing Inspections 39 2/12/09 8:16 AM
Identify ABS defective pipe mcyr Plumbing Inspections 6 1/29/09 6:39 PM
Second thoughts about Transite heat vents kswift Inspecting HVAC Systems 6 6/14/06 8:55 PM
