gloughman is a non-member guest and is in no way affiliated with InterNACHI or its members.
I am looking for some enlightment regarding what I found, or at least think I found, on an inspection yesterday. I am relatively new in the business (two + years) and I haven't run in to this before. House had split AC system with evaporator coil, horizontal-flow furnace & air handler unit in the attic. What has me perplexed is that there are two air conditioner condensing units (ACCU's) outside for this single system. One ACCU is 1½ ton and the other is a 2½ ton. Is it possible to have two working ACCU's for a single evap coil? How does this work? I have never seen anything in literature about this arrangement. If anyone out there knows what this is all about, I would appreciate a shout.
Thanks much, Gary Loughman Assured Home Inspections, Pllc |
Did you see 2 sets of refrigerant lines in the attic? I doubt that a single evap coil would have 2 condensing units in a residential setup. There might be 2 coils in parallel, providing 2 stages of cooling, though. If you didn't see both sets of refrigerant piping, then there may be a coil at another location for a separate zone.
Jim King |
Looking at my digital picture, I am only seeing one set of refrigerant lines at the coil location. This is a small one story place and there is only one zone. Outside , each ACCU has there own refrigerant lines that enter the house going to the attic. I am sorry that I haven't figured out how to send the picture along with my message.
Gary |
Gary,
If two sets of lines are entering the house, and you only saw one set in the attic, then the other set must be going somewhere else. Perhaps to a wall mounted unit in the master bedroom? Jim |
Jim,
No wall units anywhere. I may try to go back and look this over a little better than I did the first time. Because I hadn't seen anything like this before I should have been more of a detective to find out more about what I was looking at. Thanks for your help. Gary |
If you've got two Condensers, you got to have two air handlers. The attic unit usually conditions the upper floor. There's got to be another air handler in the lower crawlspace/basement area somewhere.
Are these two Condensers the same age? |
Frequently the two line sets were joined in a common conduit and appeared to be a singe installation inside the house. There was also an occasional attempt to use two small condensers in place of a larger unit (sometimes the cost difference was enough to do this) by joining the two lines into one larger line set. There were about 200 reasons why this didn't work, but you never know until you try. "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
Was that the side by side evap unit?
To David Valley,
Thanks, but there is only one floor, 1,144 sq.ft., on pier & beam. ACCU's are same age. To Jae Williams, Thanks, I thought I was going nuts or something. Gary Loughman |
Hmmm...Never seen such an animal in my area. |
You stated.... Quote:
Four tons of cooling is way too much for 1,144 SF, even in hot, humid Houston. I suspect one of those condensers was abandoned when replaced by the other.
Jim King |
James is correct, thats way too much cooling for that size home even in Texas. Did you run the ac units to see if they both ran at all.Without seeing the set up,I would go with possible abandoned unit also.Matt
My 1st question is did you try to operate the AC system with automatic controls? If you did, did both condensers operate?
If there is no 2nd air handler in the house, then consider the possibility that the AC had been swapped out at one time or another and whoever did the changeout didn't remove the old condenser. Just a thought. |
I don't know if the system got too far away from the mid-west. "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin Last edited by jwilliams4; 4/30/07 at 2:22 PM.. |
