An Ounce of prevention is better than a pound of cure :} |
| Need a home inspection in Delaware? Check out InterNACHI's listing of Delaware certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Where is the isolation valve?
Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
Line is fine
Do the laws of physics apply there?
Or do we have a code Inspector hat on. |
You claim the CSST is (blanket statement) OKAY. It may not be allowed in California. The California inspector needs to verify with a qualified CA source, just as you would if someone in CA gave you an opinion for use in Chicago. Get it? Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Do you understand what I am saying ? Now tell me how what you see in the picture is an issue and why in your own words. |
Looks like it might be an issue ........................in California.
BPI Certified Professional Building Analyst BPI Certified Envelope Professional Infraspection Institute Certified Level II Thermographer # 8510 www.dapkusinspections.com www.chicagoinfraredthermalimaging.com www.mychicagohomeinspector.com www.commercialbuildinginspectionchicago.com Professional Infrared Network Chicago Energy Audit Aerial Infrared Inspection Certified Infrared Thermal Imaging |
Appearantly you don't understand what I'm saying. Never said it was an issue, just that it could be in a state 2,000 miles away! Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Hopefully his report isn't already sent off with potentially bad information listed! Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
It will be OK if they're confused with 200 unrelated photos in the report.
If you're referring to Bob, I defer all comments to yourself! Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
clambert2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Yes, per the UMC. Decorative logs can have flexible gas line connector. Gas log lighters must have solid pipe.
Hope this helps Last edited by clambert2; 1/21/12 at 1:37 PM.. |
FWIW - CSST is gas piping. Appliance connectors (although made of the same material) do not qualify as CSST. They are pre-assembled, listed "connectors." Rules for installation of CSST are different than rules for use of appliance connectors. CSST is also allowed in CA. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
| Gas Line to fireplace | jharrison | Plumbing Inspections | 8 | 12/28/10 10:00 PM |
| Fireplace clean and scan | dmacy | Interior Inspections | 4 | 11/21/10 8:16 PM |
| Coming soon. Free, online, fireplace and chimney inspection course. | gromicko | General Inspection Discussion | 15 | 12/14/09 4:19 PM |
| Hearth size??? | jcampbell | Inspecting HVAC Systems | 32 | 6/1/08 1:56 PM |
| TPRV line and condensate line marriage | ccarrington | Plumbing Inspections | 3 | 4/29/06 7:59 AM |
