Are there any concerns with an empty unused underground storage tank. My guess is that it used to be for heating oil. Sorry I did not take any pics. The only part that is visible is the cap and it just flips open. The buyer is concerned that he might have resale problems later and be responsible for a major clean up. EPA problems etc.
I would write this hard as It could come back to haunt you . How do you know it is empty. How do you know it has not had a hole punched in the bottom to let out the oil or it could have rusted out . Contaminated soil costs about $4,000;00 a yard to be shipped away. There could be up to $400,000:00 or more cleaning this up so do Not miss a buried oil tank in our area ,Ontario Canada. I think this could call for an environmental impact study to be sure . defiantly get your client to ask the authorities. Please keep us posted . .... Cookie If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
Thanks everyone.
Seth N. Glick;
Please heed this advice from above, this situation needs to be addressed promptly and would be a safety hazard left unnoticed and noted as such. There is no such thing as an empty oil tank unless there is a hole in the bottom of the tank and then you have a DEP,EPA situation on your hands with the Client and could be held responsible. Notify the Client to have the seller clean it up immediately before any anticipated closure of the deal. Let us know what happened. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
As a matter of note here in Fl if the tank is under a certain size the Fl EPA does not care
To compute the size one is to probe with a rod to get the aprox size and assume that it is pipe shape. Standard volume calculations are made and if you are under no big deal The state EPA will help with all the information. There are so many of them they only care about the big ones Good find - this might help both the seller and the buyer Information is the answer as to the requirements in your area rlb |
What I found out in Utah:
If the tank is residential and under 1100 gallons the the EPA does not care and has no jurisdiction. It falls under the local Fire Marshall, so you need to check locally on any requirements. However there still could be problems if the ground has been contaminated, but there is no way to know that unless you dig up the tank. At a minimum the tank should be cleaned and filled with sand to prevent the possibility of any future contamination and to prevent the ground from caving in with the tank. I would still recommend inspect by a professional and that they make contact with the local EPA office and local officials because of the clean up potential. I do not think they see it as a big deal here in Utah because there are not very many of them here. I know it is a real big deal in NY because they are all over and still being used. Thanks Everyone. |
The State Fire Marshall in Illinois also has records of buried tanks beginning in 19??
Underground oil tanks...
That reminds me of a “call” I received a year or so ago for an inspection that I did about 2 years before that. Hi Larry, you did an inspection for me a couple years ago and I’m putting in footings for a block privacy wall and we think we hit an oil tank. Who’s responsible for that? Well, let me dig out the report and get back to you… I retrieve it and in the basement or heating section is this: “Two 3/8” copper lines cut off near the furnace exiting through the basement wall indicate the potential for an underground buried oil tank. I recommend further investigation by a qualified professional, with remedial action as needed, before the close of escrow.” So to be helpful, on the way to another inspection I stop over there and talk and I end up giving him a couple of names of people that deal in that sort of thing. Someone cut the fill/vent pipes below grade but didn't think anyone would notice the other lines, I guess. He was happy, since the tank was dry, and I was happy to help. He built a really nice wall, too. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Anytime there is a residential or light commercial heating oil spill or leak, anywhere in the system, you are potentially talking BIG bucks:
"In 2001, DEP conducted a survey of 510 homeowners who had experienced a home heating system oil spill. Questions included how long the cleanup had taken, the costs involved, and whether soil and/or groundwater were affected. Cost data were provided by 159 homeowners. Costs were significantly lower when homeowners cleaned up spills quickly and prevented impacts to groundwater. Prompt cleanups also minimized disruption and reduced the potential for exposure of family members or neighbors to the oil. Survey data indicated that spills that had time to spread to groundwater were significantly more expensive to clean up. Most cleanups completed in four months or less: $20,000 or less. Typical cleanup cost range: $20,000 to $50,000. Average cleanup costs involving both soil and groundwater: $90,000. On the high end, DEP survey results showed some cleanup costs exceeded $300,000. While the survey answers were not detailed enough to show all the factors that caused costs to escalate to this level, impact to groundwater was a factor..." http://www.mass.gov/dep/cleanup/homework.pdf One of the better "end user" articles I've found on this issue: http://www.newsday.com/features/home...7731926.column |
To see how bad this problem is
We have properties that are so bad here in town that one can not even give them away Bank will not loan money on them etc. The sale value of the property is less that the clean up. The original owner will be leasing it for ever to some one - he can't sell it Clean up is out of the question Many have decided to "clean up" under the table and have it tested (which it will) and keep their mouth shut And if you sell to a gas station they are most times exempt You also donate the property to a church or the city etc. So take the tank out at nite and sell it for scrap As an inspector you did a good job and you might have done a deal breaker that in reality is no big deal Look at it this way what if the owner wants to still use the tank -- It is still legal if he wants to and it is in good condition. Local conditions must be checked - In some areas a septic tank must be inspected now and then with local permits renewed Bless the government rlb Last edited by rbennett; 10/22/07 at 9:49 PM.. |
This might help
http://www.edrnet.com/index.php?opti...133&Itemid=253 |
I disclaim anything underground in my agreement. Nevertheless, I say this when I come across one:
"One or more underground fuel storage tanks likely exist on the property, as we noticed a fill pipe in the yard. As mentioned in our contract, we do not inspect underground storage tanks. We offer this information as a courtesy and you may want to further investigate the tank, its contents, and the potential environmental ramifications associated with its presence." “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
I did a very small Home In the country 4 years ago found inside oil tank had leaked 100 gallons.
House sold for $79"000:00 on condition it had the oil contamination cleaned up . Clean up cost $76'000;00 . Not much profit there. Today that would cost a lot more to clean up. Please do not miss an oil leak. .......... Cookie If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
| New Washington Legislation Submitted | gdomagala | Legislation, Licensing & Legal Issues for Inspectors | 293 | 2/10/08 2:20 AM |
| Septic System Care | mlarson | Ancillary Inspection Services & Additional Topics | 49 | 8/31/07 11:26 PM |
| Buried Oil storage tank | brepanshek | Inspecting HVAC Systems | 6 | 1/29/07 11:07 PM |
| heating oil storage tanks | jclark1 | Plumbing Inspections | 2 | 2/12/06 10:55 PM |
