I have not come across this doodad before but I'm sure there are more experienced inspectors then I who have. It was attached to the line coming off the drainage bib on the bottom of the water heater. Input regarding identification and function will be appreciated.
mike in MN |
| Need a home inspection in Connecticut? Check out InterNACHI's listing of Connecticut certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Timer controlled circulation pump.
Did you look at the piping to see if it had a return pipe or if it uses a crossover valve under a remote sink? B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
thanks for the enlightenment. following the link from roy it appears this is a device simply to cirulate hot water enough so there is no wait period for same. so there must be some kind of loop. the site didnt really explain much of how it worked. of interest i note that it was said that this device hooks to the hot water line from the heater. apparently (or so this plumber thought) hooking to the drainage faucet was also a working deal. so i kind of have a little understanding of this unit....thanks! i will certainly read any further explanation
MN mike |
If you look at the Picture of the watts there is a Connector to the cold water line That is used as the return so you have hot water instantly at the tap . If you look at my first picture you see mine is silver . There is a thermostat in the line so when How water arrives it shuts the valve when it cools the valve opens again . Come on Up to Canada and see how well mine works . All the best Roy Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
thanks....this MN inspector is now armed with newly acquired wisdom
cool mike in MN |
| Tankless water heater issue | sstanczyk | Plumbing Inspections | 18 | 12/2/10 6:15 PM |
| Solar water heating + electric water heater | Todd M. Soper | Plumbing Inspections | 20 | 5/30/07 6:31 AM |
| Need Help On Chimney Liners | Nick Scibetta | Exterior Inspections | 13 | 1/11/06 9:53 PM |
