gbrasseur is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hi HVAC experts,
I know this may seem elementary to some of you, but I am new and still learning. This house was built in the mid 60's and the furnace was replaced in the late 90's. Here is the question, the furnace "shut off" has a fuse as seen in the one picture(sorry it is sideways). Would you call this out to be "upgraded"?? The house main has breakers. Not sure where to go with this one. Thanks in advance. Regards, |
I've seen alot of things like that--a single fuse for a particular appliance. Some AHJs have no problem with it and approve the installation. You might check with the local AHJ and see what they say.
I've seen many HVAC's installed today have fuses. There seems to be installation instructions that require it, do convert them to breakers could violate warranties, and create dangerous situations.
Example: < 15amp breakers are uncommon, but you can smaller fuses, so you might be overrating the furnaces ocp. tom |
Hi. Gregg;
I think the fuse is OK if it is rated for the wire and amperage. I think you need to note that althought Duct Tape is spelled like Duct, it does not mean that it is for Duct joints. If you know what I mean. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
That is when you take your knife and peel the brass threads and bend it under the fuse and put it back it, right.??? Next to the best thing of a penny I believe. ha. ha. Seriously, hope no one does or tries this. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I am still trying to figure WHY they used that duct tape? I planned on calling it out, but couldn't figure why they would do it. |
Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging Last edited by cbottger; 3/3/07 at 12:41 AM.. |
tneumann is a non-member guest and is in no way affiliated with InterNACHI or its members.
Greg...are you talking about the fuse for the Emergency Shut off application?
And...something a wise 'old inspector told me It isn't important WHY the dipsh8t used the duct tape...what is important is that he shouldn't have. |
![]() And yes on the emergency shut off Tony. How are you by the way? Hope your good buddy! Last edited by gbrasseur; 3/3/07 at 11:37 AM.. |
Thank you for that link! |
It is most normal to see a switch fuse unit on a furnace. This is for a several reasons. One, as has already been mentioned, some central heating equipment calls specifically for fuse protection. Second, it would be normal to find these fuse units with 6 or 8 amp fuses installed, as per the heating equipment manufacturer's specifications. Third, in days gone by, with very small fuse panels protecting homes, the fuse panels had a set of "subfeed lugs" marked "heater lugs". These were lugs basicaly unfused terminals, and intended to go to future central heating equipment that may require an electrical connection, and required their own fuse protection at the central heating unit. As a result, these switch fuse units were in use from "way back", and it became tradition for furnace installers to continue to use them to modern times, even if not otherwise expressly required. Fuses continue to provide superior protection over circuit breakers. It is people who install the wrong size fuse or bypass the fuse protection who create the hazards blamed on fuses.
| Fuse box puzzle (with photos) | abolt | Electrical Inspections | 2 | 8/5/07 3:28 PM |
| Fuse box puzzle | abolt | Electrical Inspections | 0 | 8/5/07 2:34 PM |
| Fuse Panel Questions | pdoane | Electrical Inspections | 8 | 9/21/06 8:37 AM |
| FPE Fuse Panel | rarmstrong1 | Electrical Inspections | 2 | 6/3/06 5:22 PM |
| Max fuse ratings | dmacy | Inspecting HVAC Systems | 15 | 1/19/06 11:35 PM |
