mnicholet is a non-member guest and is in no way affiliated with InterNACHI or its members.
What do you think about this vent connector slope for a natural gas fireplace/stove.
Could be fine...I'd have to see the manufacturer's install instructions to be sure.
In 1989, I worked on the local portion of a cross-country study on IAQ. It found that 39% of oil and gas installations had draft problems and were borderline for gas spillage upon startup!! Some corrected within seconds but some took almost a minute......too long to be spilling combustion gases into a living space! It would take very little to tip the scales to longer or constant spillage. WETT #572 Master System Advisor Last edited by Brian A. MacNeish; 9/20/08 at 2:56 PM.. |
Thanks, great information. Very good reminder regarding the chimney location. This chimney was actually an external chimney installed several years after the home was built with a 2 inch gap between the masonry and the cladding and lateral supports every 10 feet. I sometimes find spillage on gas appliances with my carbon monoxide detector until it reaches its steady state.
| Pellet stove help | chellickson | General Inspection Discussion | 23 | 8/19/10 1:23 AM |
| Plumbing vent next to exhaust vent | mpettitt | Plumbing Inspections | 5 | 10/12/07 5:38 PM |
| Air admittance valves everywhere | apfaff | Plumbing Inspections | 13 | 4/16/07 9:17 AM |
| Gas and oil hot water tank and Boiler Share Vents | hvanderbeek | Miscellaneous Discussion for Inspectors | 8 | 1/25/07 5:22 PM |
