brepanshek is a non-member guest and is in no way affiliated with InterNACHI or its members.
Is any single wall vent piping allowed in the attic space? Example...their is a gas furnace located in the attic space, the vent pipe consists of a 1) single wall 90 degree elbow into a 2' piece of single wall metal pipe into a verticle b-vent that exits thru the roof.
Is this small portion of single wall pipe ok in attic area??? |
Brian,
Code in our area allows for a single wall elbow or start collar (less than 4") at the draft diverter collar on the furnace, then double wall (B'vent) thru the roof. Good Luck |
| Do you put polybutylene in the Summary? | jfunderburk | Plumbing Inspections | 36 | 10/27/10 11:21 AM |
| Help - Polybutylene Pipes | Rick G | Plumbing Inspections | 39 | 2/12/09 9:16 AM |
| Identify ABS defective pipe | mcyr | Plumbing Inspections | 6 | 1/29/09 7:39 PM |
| Vent pipe | dlee2 | Plumbing Inspections | 4 | 9/18/07 12:28 AM |
